997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
GT4
Nordschleife
Nordschleife
PostPosted: Fri May 30, 2014 10:16 pm    Post subject: Reply with quote
I too worked out an ideal solution (and the equivalent fractional solutions)
And the one I implemented was the most appropriate to the existent hardware (ie there is a certain beauty in reusing the PCB with the fewest cuts)
You should also consider any array's sensitivity to voltage drift (for me, the brake lights must work both with engine off: 11.5-12.5v and with engine running alternator: 14.5v)
If you run the max current calcs on both extremes on the non-linear LED characteristics, you realise you are better (more tolerant) running external voltage drops across linear reisistors.
Any way, long story short, if you use "normal" 2.5mm diameter resistors (in high power design), the headroom is plenty in the back of the brake light enclosure (cf the 1.5-2mm diameter of the standard wiring etc that already fits in there: just cut the supply cable and run the resistors in series) .
EDIT: just look at the supply tabs (spades) on the track side of PCB, they are circa 3mm off the board, and accept the female spade caps too (adding 1+mm), so you can see the resistors are easily lower than that.
NB: you will need to extend one side of the internal supply wiring/cabling by about 20cm (from memory) anyway, as I flipped one of the original entry/exit supply tabs to be opposite end of the PCB: my current runs from one end of the PCB to the other (via alternating batches of LEDs on the array "ladder"), unlike the original 100% parallel incandescent bulb design (which had a top and bottom/positive and negative supply "bus bars").
PS - I should perhaps have updated this thread, but still wanting more power, I tweaked the current even higher (it was technically on the conservative side of the available 8,000 mcd), so I swapped one pair of resistors for 23R (IIRC).
ie 11.5R effective @ 1.2W max on one end, and 23.5R @ 1.2W max at the other (don't forget to stagger the resistors for most efficient packing).
So a drop from 47R total, to 35R.
You may wish to start @ 47R|47R x 2 too, and see how you go, intensity wise (given current LED output characteristics may be better now any way), and drop down as you see fit.
RobIpswichUK
Watkins Glen
1994 Porsche 993 Carrera 2
PostPosted: Sat May 31, 2014 8:54 am    Post subject: Reply with quote
orangecurry wrote:
arrrrrrrrgh I don't understand!
I don't understand either.
GT4 - Any step by step instructions on the array wiring for Electrical numpties (like me)?
Rob
'94 C2 Iris Blue (+ White Stripes!) Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230 lowered + AMG wheels)
Range Rover Sport V8 (L320 chipped)
TT Roadster (standard - wife’s daily!)
W211 E320CDI Barge (must not forget - NEED TO SELL!)
E91 320d SE Touring (must not forget - NEED TO SELL!)
Big Jock
PostPosted: Sat May 31, 2014 9:11 pm    Post subject: Reply with quote
Is all that supposed to be interesting?
GT4
Nordschleife
Nordschleife
PostPosted: Sat May 31, 2014 11:19 pm    Post subject: Reply with quote
The recipe for meringue is invariably less enjoyable than the eating.
GT4
Nordschleife
Nordschleife
PostPosted: Sat May 31, 2014 11:22 pm    Post subject: Reply with quote
I'll draw a picture next time I'm on the PC.
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Sun Jun 01, 2014 7:34 am    Post subject: Reply with quote
Great quote.
Smile
Citori
1996 Porsche 993 Carrera 2
PostPosted: Sun Jun 01, 2014 11:37 am    Post subject: Reply with quote
OK. Thanks for that information.
I will try the 47R resistors first off and see how I get on, also I have some of these to hand which helps.
I agree that the less chopping about of the original board the better so I think I will follow your original example.
The thing that bothers me the most if getting the top cover off without damaging it! It does seem very tightly fixed on.
Off on holiday pretty soon, so I will get to it when I get back.
Thanks again for the info.
ATB
Steve.
Previously enjoyed Porsche:
1996 C2 Coupe.
1983 911 Carrera Targa Sport.
1981 911SC Sport.
1978 911SC.
1970 911E.
I have CDO. It’s like OCD, but the letters are in alphabetical order, LIKE THEY ARE SUPPOSED TO BE..
Aircooled or nothin....
Citori
PostPosted: Sun Jun 01, 2014 11:44 am    Post subject: Reply with quote
Rob.
If I get mine working OK I will do yours for the cost of the parts and breakfast at The Hare. How's that for a deal?
1996 C2 Coupe.
1981 911SC Sport.
1978 911SC.
1970 911E.
RobIpswichUK
Watkins Glen
PostPosted: Sun Jun 01, 2014 12:09 pm    Post subject: Reply with quote
Rob.
Done
Rob
GT4
Nordschleife
Nordschleife
PostPosted: Sun Jun 01, 2014 5:04 pm    Post subject: Reply with quote
PeterS wrote:
Great quote.
Smile
It wasn't a quote (although it is now) worship
GT4
Nordschleife
Nordschleife
PostPosted: Sun Jun 01, 2014 5:06 pm    Post subject: Reply with quote
Rob.
I'm assuming my usual 15% applies here? food food
GT4
Nordschleife
Nordschleife
PostPosted: Sun Jun 01, 2014 5:15 pm    Post subject: Reply with quote
ATB
Steve.
The high level brake light enclosure is sealed with an adhesive foam gasket.
I deliberately didn't refer to it as "sticky", because it no longer is (it may have been set/hardened at factory, but it is certainly set now!)
You will need to carefully pry it away from one side (back lid) using a thin, but not sharp tool (I slowly slid a needle along the join).
Once the LED work was complete and rehoused, I carefully "painted" the foam gasket with a PVA glue using a thin artists paintbrush and reassembled the back to seal it up again.
GT4
Nordschleife
Nordschleife
PostPosted: Sun Jun 01, 2014 6:43 pm    Post subject: Reply with quote
PCB diagrams
Click here for larger
NB:35-47R is appropriate for use with the 2.1v / 20mA LEDs I used.
Using 4 individual resistors allows greater total power rating than one single equivalent resistance resistor of the same physical size.
If the operating parameters of your LEDs differ, you will need to calculate new resistors (resistance and power ratings).
If you use higher intensity LEDs, you may need to decrease the current too.
GT4
Nordschleife
Nordschleife
PostPosted: Sun Jul 20, 2014 8:39 pm    Post subject: Reply with quote
Centre caps @ 14 v3 now (Schwarz, L744)
Nut caps @ 15 v2 now (Black * 20)
stuttgartmetal
PostPosted: Mon Jul 21, 2014 4:21 am    Post subject: Reply with quote
Wheels off to change centrecaps?
PostPosted: Mon Jul 21, 2014 9:05 am    Post subject: Reply with quote
How come the spokes are black Dont know
The game's afoot. It's time to put a bit of (Colini) stick about......"Shall I open her up Miss Jones and show 'em a clean pair of heels?" "Do you think that's wise Mr Rigsby this is a very old car"
GT4
Nordschleife
Nordschleife
PostPosted: Mon Jul 21, 2014 11:16 am    Post subject: Reply with quote
Yes.
But how often do you change centre caps and not the wheels Dont know
Stops then getting nicked and I don't think plastic suits the 993.
GT4
Nordschleife
Nordschleife
PostPosted: Mon Jul 21, 2014 11:21 am    Post subject: Reply with quote
I think Exel Wheels are to blame.
Just to clarify - last night's post was a progress update (the original thread is TWO years old now), I also updated my garage mods (click my sig pic below or "1996 Porsche 911" linky in the bar to the left under my post count)
So all 34 are now listed (or corrected, if removed or replaced), with relevant photo evidence and/or linky thread.
Wheel refurb is #30.
Other threads have been updated, but I just edited them, rather than added a post - which of course, in this case, had the unintended consequence of bumping up an old thread and begging silly questions.
But fire away ...
Goto page Previous  1, 2, 3 ... 23, 24, 25
Page 25 of 25
