997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayenne : 2003- 7
GT4
Nordschleife
Nordschleife
PostPosted: Wed Apr 17, 2013 7:39 am    Post subject: Reply with quote
ollster wrote:
Looks good although i quite like my smaller tech art hideous wheel Wink
You should realise by now, my turn of phrase is deliberately used to elicit a "discussion" (there's nothing worse than a post without a reply...) Wink
PostPosted: Wed Apr 17, 2013 9:03 am    Post subject: Re: All aboard! Reply with quote
GT4 wrote:
Thought I'd update with a better picture (now the car is enjoying the sun again):
worship
How many miles are you planning to add to the 126 already racked up in 2013. Question
GT4
Nordschleife
Nordschleife
PostPosted: Wed Apr 17, 2013 4:41 pm    Post subject: Reply with quote
Is it that much Surprised
All I can hope for is more SNOW!
kench
2007 Porsche 997 Turbo
PostPosted: Thu May 16, 2013 11:18 pm    Post subject: Reply with quote
GT4 wrote:
Thanks for exact numerics.
Yep, diagnostic cable and touch/visual confirm of WOT/TPS planned at the weekend.
To be honest, the prospect of possibly finding another 10-15 horses appeals more than just knowing the position is correct.
Just ordered one of these too, in theory allows ODB2 diags via WiFi to iPad/iPhone.
Will advise after testing.
Sorry to bring this thread up again.
GT4 were you impressed with that reader?
GT4
Nordschleife
Nordschleife
PostPosted: Fri May 17, 2013 7:58 am    Post subject: Reply with quote
Yes, but it is not capable of Porsche specific settings, like a Durametic nor its data logging capabilities (although that is just a software change that would allow it).
It is mostly its universality that impressed (and some of the nice skins available to display up to dozens or more sensor outputs from modern engines/vehicle bus).
PostPosted: Fri May 17, 2013 9:25 am    Post subject: Reply with quote
Gt4 what were you findings re WOT and cable stretch ?
It is something I've not looked into on the 993 yet but on older BMWs it is a common issue along with the internal wire lubrication degrading.
It is usually an easy visual check that WOT is being achieved and the throttle body connection will allow a certain degree of adjustment to account for stretch before a new cable is needed. I assume this is the case for the 993? It is something I will check when I'm back in the UK
Also did you keep the original mod to lift the peddle? Or revert it back due to any adverse effect on the cars reading of the pedal position as implied above ?
GT4
Nordschleife
Nordschleife
PostPosted: Fri May 17, 2013 10:57 am    Post subject: Reply with quote
Not sure how moving the pedal OFF position can affect the TB/fuelling sensor.
The engine (DME) is only aware of any movement AT the engine end when the cable is moved (I haven't changed the stops or detents) - I could take the pedal off and it wouldn't know.
I have left mod as is, as I detected no over strain or over reach to the cable, either via cable tension or at TB lever angle on back of engine.
There is still a chance the cable is still under pulling (due to suspected stretch), but the at-pedal mod was meant for heel-and-toe benefits, so as I don't drive WOT, it makes little difference if it is still only achieveing 97% (so I haven't spent much time on that aspect).
One presumes that any change I have made inside the maximum parameters tends closer to true WOT.
acamp76144
PostPosted: Thu Sep 26, 2013 8:08 pm    Post subject: Reply with quote
Whats your view on the chip having had it for a while now?
GT4
Nordschleife
Nordschleife
PostPosted: Thu Sep 26, 2013 8:14 pm    Post subject: Chips with everything Reply with quote
I wouldn't change it (YMMV)
Others have complained it is not compatible with the 200 cell cats for emissions or that it has even damaged (burnt) the cats.
But then that is mixing two non-OEM mods, so there can be no guarantee on their compatibility.
I was privileged enough to try three different maps (chips) and chose the one I liked (performed) best.
So in a way it was tailored to my cars parameters, albeit by trial and error.
MOT in May was fine.
My god it has grunt now: the Varioram kick feels almost like a turbo kicking in and it genuinely gets quicker over 5k rpm.
adamw
Estoril
1998 Porsche 996 Carrera 2
PostPosted: Thu Sep 26, 2013 8:35 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?t=72694&postdays=0&postorder=asc&start=45
nooo
98’ 996 C2 aero, Swartz Black, GT3 style fixed buckets, GT3 momo steering wheel, GT3 wheels, KW’s + lots more
EX : 02' 996 Turbo Coupe ( May 17 - Sept 19 )
GT4
Nordschleife
Nordschleife
PostPosted: Thu Sep 26, 2013 9:10 pm    Post subject: Reply with quote
Yep, mentioned that in the first line obliquely (YMMV) and more specifically in the second para.
adamw
Estoril
PostPosted: Thu Sep 26, 2013 9:20 pm    Post subject: Reply with quote
I know, but thought id post just for completeness and so all info was available. Personal preference I guess Dont know Thumb
Whats "(YMMV)" Question Embarassed
GT4
Nordschleife
Nordschleife
PostPosted: Thu Sep 26, 2013 9:27 pm    Post subject: Reply with quote
Sorry, just didn't want you to think I had glossed over that, and I also tried to *guess* the possible reasons for the variable results from the chip + cats.
YMMV = (horrible Americanism) "Your Mileage May Vary"
ie you may get different results
PS - is your's a VR?
adamw
Estoril
PostPosted: Fri Sep 27, 2013 5:43 am    Post subject: Reply with quote
No probs, Cheers
Pre-VR
GT4
Nordschleife
Nordschleife
PostPosted: Fri Sep 27, 2013 7:50 am    Post subject: Reply with quote
So you can't have the same map as me?
(even discounting the 1 in 3 VR maps "choice")
You should be running a non-VR map.
cambjones
1997 Porsche 993 Carrera 4
PostPosted: Fri Sep 27, 2013 10:05 am    Post subject: Reply with quote
I have one sitting in my bed side table that I've never installed in case anyone wants it half price... I have 200cell cats so I've been hesitant to install it, but if others are have standard cats and are comfortable with the risk let me know and it is yours. I'm going to get a Wayne remap so I wont have any use for it.
Otherwise I might just stick it on ebay, if I get around to it.
adamw
Estoril
PostPosted: Fri Sep 27, 2013 1:58 pm    Post subject: Reply with quote
cambjones wrote:
I have one sitting in my bed side table in case anyone wants it half price...
Otherwise I might stick it on ebay, if I get around to it.
+1 Thumb
berni29
PostPosted: Thu Oct 03, 2013 3:19 pm    Post subject: Reply with quote
Hi Cambjones
Do you know what the rev limit is set at on your chip? I have one in mine at the moment that clashes with my Tiptronic box up changes. i.e. the limit is a little low.
I wonder if the Tips use a different chip? I thought not.
Berni
993 C2 Tip 1994 187k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris.
cambjones
PostPosted: Thu Oct 03, 2013 5:21 pm    Post subject: Reply with quote
berni29 wrote:
Hi Cambjones
Berni
Hey Berni, I have no idea. Do you know how I would tell? I have never installed it either. You are more than welcome to try mine out if you like.
I'm pretty sure he has specific chips for specific cars though...
Fuchs
Shanghai
1994 Porsche 993 Carrera 2
PostPosted: Mon Jan 13, 2014 12:29 pm    Post subject: Reply with quote
Back to the battery cut off - in this months (Feb 14) 911 and P World mag there is a tried and tested article on a 993 (page 115) where the author (consultant editor Chris Horton)states it has a battery cut off fitted "correctly to the postive battery cable"
All the sources i would find online state that the battery cut off should be fitted to the negative terminal.
Who is right?
BTW - mine is fitted to negative as is GT4´s.....
Dont know
1994 Carrera 2
Ex 1984 Carrera 3.2
Goto page Previous  1, 2, 3 ... 22, 23, 24, 25  Next
Page 23 of 25
