997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 25
Cayenne : 2003- 7
Post new topic   This topic is locked: you cannot edit posts or make replies.
Gibbo205
PostPosted: Fri Jul 08, 2011 2:19 pm    Post subject: Reply with quote
wizard993 wrote:
I have switched completely to the Total Porsche Approved Oil. Indications are that it keeps the 996/997.1 engine slightly cooler. I also use the GT2/turbo thermostat on the 997.1. It runs a shade cooler now. Each week/fortnight I scoop out front rad debris(next doors 7 year-old helps...errr well he often does it, as his small arms and fingers are ideal for getting to the rads. He is happy with a mars bar as his reward: thumb:
Budget(£350-£400) + VAT supplied and fitted for the thermo upgrade at any decent Indy(inc coolant).
What is the part number for the thermostat you got m8?
Is the one Hartech sell something different again?
GT4
Nordschleife
Nordschleife
PostPosted: Fri Jul 08, 2011 2:20 pm    Post subject: Reply with quote
wizard993,
What percentage of the total average annual spend do you believe is in per capita Mars bar expenses?
Philosophical question of the day:
Is the Porcshe IMS bearing seal as useful as a chocolate (of your choice) teapot?
Second philosophical question of the day:
If an IMS bearing falls over and no-one is listening, does it make a mess?
Third philosophical question of the day:
In Schrödinger's Porsche, is the IMS bearing sealed or not sealed prior to Baz opening the box and killing a cat.
wizard993
1966 Singer Gazelle
PostPosted: Fri Jul 08, 2011 2:23 pm    Post subject: Reply with quote
Just give autofarm a call. They can deliver to you or directly to your chosen Indy. No idea what others sell(maybe the same one from the states) but quality spot on and fitted without fuss/trouble.
"The smallest feline is a masterpiece"
- Leonardo da Vinci
GT4
Nordschleife
Nordschleife
PostPosted: Fri Jul 08, 2011 2:26 pm    Post subject: Reply with quote
wizard993 wrote:
Just give autofarm a call. They can deliver to you or directly to your chosen Indy. No idea what others sell(maybe the same one from the states) but quality spot on and fitted without having an argument.
EFA
wizard993
1966 Singer Gazelle
PostPosted: Fri Jul 08, 2011 2:32 pm    Post subject: Reply with quote
GT4 wrote:
wizard993,
Circa 20/30 bars each year @65p each = £18/year (if I can catch him early enough, before he goes to the army cadets on a Saturday) lol
Is the Porcshe IMS bearing seal as useful as a chocolate (of your choice) teapot? Like some parts on 911's the mind boggles as to why they did/engineered that.
yes it will but usually the driver gets the death click and rumble before the whole lot/IMS/crank and 6+ litres of oil let go. Then, as if by magic the "I love ***tech tee-shirt" arrives in the post lol
- Leonardo da Vinci
Gibbo205
PostPosted: Fri Jul 08, 2011 2:34 pm    Post subject: Reply with quote
wizard993 wrote:
GT4 wrote:
wizard993,
Circa 20/30 bars each year @65p each = £18/ayear (if I can catch him early enough, before he goes to the army cadets on a Saturday) lol
What is this death click/rattle you all go on about?
My exhaust crackles/pops when cold, I assume its normal as Mike from S&C has used my car and commented on the nice crackle from cold. Smile
wizard993
1966 Singer Gazelle
PostPosted: Fri Jul 08, 2011 2:37 pm    Post subject: Reply with quote
It's when your piston coating starts to fail and the piston starts to munch away at the cylinder walls. By that time you should be Sad starting to ££save up.
Exhaust crackles are the norm...enjoy Thumb
The death click is a regular ticking sound(not to be confused with the normal value train noises).
- Leonardo da Vinci
s2000db
2011 Porsche 997 Turbo S
PostPosted: Fri Jul 08, 2011 2:46 pm    Post subject: Reply with quote
Interesting thread.... Errr I think, but can we not get things in a little context here please..
Firstly what is the actual percentage of engines going pop in any manner over say the last 5-6 years and how does that compare to it's competitors?
And secondly, why be at all concerned by the service/ oil change intervals, if you follow the schedule, and have an extended warranty?
Over the past ten years, I've done highish mileages in 996/7's, and have never had any issues aside from a couple of RMS replacements (under warranty)..
Lambo Huracan Performante
997 TurboS
997 C2S
996 C4
bazhart
Approved Trader
PostPosted: Fri Jul 08, 2011 4:11 pm    Post subject: Reply with quote
I just found 5 minutes before going ome - I'll rush this as a result and therefore some spelling and typing werrors included FOC.
Interesting policy - when the title is answered but dissagrees you argue that the responses are not all about what you intended (even though they respond to the title) and you then change the title to suit your case - to make you right all along - good luck I have seen all this before.
You keep asking me to respond to your questions but never answer mine - clever again - go into politics.
Clever to post that a better quality bearing is needed when there is actually nothing wrong with the bearing.
To suggest that the bearing was designed or expected to last the life of the car and retain all its grease is utter madness and no engineer of any practical experience whatsoever would expect that outcome.
The seals are just thin little pieces of plastic designed to keep dirt out and grease in - for cool applications. To imagine that the hot thin oil being thrown at the seal at high velocity cannot start to penetrate it - and wash out the grease (after which the flow is insufficient to adequately lubricate the bearing and stop it overheating) is the comment of an academic not a practical experienced engineer IMHO.
I fail to comprehend why some people are so in love with a manufacturer they can see no wrong even when the evidence is clear. It seems the argument is - if Porsche did it or say so it must be right - then the very same people (when it suits them) argue they know better about something else.
Why did Porsche make so many revisions to the design and then eventually drop it if it was right in the first place.? Why do most of the failures occcur with cars that are still maintained by Porsche using the recomended oil?
Blind to reality comes to mind and never any answers as to how it is possible that removing the seal makes it work OK regardl;ess of the oil in use or the use the car is put to or how it is driven.
Time up.
Baz
We just supply the thermostat - if you are not capable of fitting it to the casting that doesn't need changing - you should not be changing it or the coolant or trying to bleed the system properly. This is why ours costs much less but it does the same job (although it is not the same thermostat).
Click here for the Hartech
www.hartech.org
Post new topic   This topic is locked: you cannot edit posts or make replies.   All times are GMT - 12 Hours
Goto page Previous  1, 2, 3, 4
Page 4 of 4
