997 : 2004- 65
996 : 1997-2005 35
964 : 1989-1993 1
steveoz
PostPosted: Tue Mar 22, 2011 10:05 am    Post subject: 996: Rear Window Seal Fix Reply with quote
Splitting this from other post as per Richard's advice Smile
The rear window seal fits fairly loosely on the early 996's I am led to believe. There is a TB from Porsche regarding this; the trick is to insert two lengths of Foam rubber cord under the seal.
The cord is only a few pounds from an OPC.
First, I lifted the window seal up from the corner, all along the bottom and side, I then cleaned out any gunk and moisture.
After this, I placed the seal back down and pressed down firmly all around. Then, lifting the bottom corner of the seal, I positioned one end of the foam cord under the seal:
I then inserted a plastic spatula / card between the seal and the tailgate:
This gave me an easy way to flex the window seal to create a margin to push the foam rubber cord in with another card without damaging anything:
I continued to work my way around the seal:
When the cord was fully inserted, I cut, and then repeated the process to layer two cords on top of each other to fully fill the gap as per the technical bulletin. Once that was completed, I gently went along the seal '*****' it upward to make sure that it was all in the right position and flush with the tailgate:
All done, much more solid, and sealed much better:
Cheers,
Steve
ksr
PostPosted: Fri May 24, 2013 1:43 pm    Post subject: Reply with quote
Hi Steve,
I think I'll need the foam rubber. Have a buzz from the rear screen that stops with hand pressure. Went to local OPC to ask for the foam rubber and got a completely blank look. Didn't know what I was talking about. Suggested changing the rear seal itself?? I've tried google search but to no avail. Anyone know where else I could get one??
steveoz
PostPosted: Thu Oct 17, 2013 10:01 pm    Post subject: Reply with quote
ksr wrote:
Hi Steve,
Hi, really sorry for the super late delay, I've not been around for quite a few months.
You've probably found it, but if not part code is:
996 541 903 00
Official part name is 'Round Rubber Cord'
PostPosted: Thu Oct 17, 2013 11:31 pm    Post subject: Reply with quote
996 541 903 00
>> http://www.911uk.com/download.php?id=27833
(PDF courtesy of GT4)
ksr
PostPosted: Fri Oct 18, 2013 7:38 pm    Post subject: Reply with quote
Thanks for the PDF. The noise has kinda disappeared and my c4s is MY04. I guess it should be the updated version then?!
Embarassed
