997 : 2004- 63
Boxster : 1997- 26
steveoz
PostPosted: Tue Mar 22, 2011 9:56 am    Post subject: 996: Rear ARB Bushes Reply with quote
Most people probably know how to do this, but again here are some pics I took a while back when I changed the bushes and before I replaced the ARB. Whenever I change rollbar bushes I always put the car on axle stands then jack the hub to take pressure off of the bolts and keep the bar in the correct position. It makes it a real quick job. I also put some silicone on the bar so the new bush slides on nicely when replacing and clean the threads / grease all old bolts (as I do if reusing any bolt on the car). I didn't have any symptoms, but the OPC tech on the inspection said they were wearing. I've had knocking on other cars when these do go though where the ARB hits the mount.
The axle stand here in the picture was placed on the chasis rail where the wishbone joins as a temporary measure (incase the others failed).
