997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
michelin
2006 Porsche 997 Carrera 2
PostPosted: Sat Jan 15, 2011 10:08 am    Post subject: Do headlights have to be removed to remove the front bumper? Reply with quote
Just in the process of this now. I only want to give the rads a quick clean etc and not really keen on remving headlights in case they dont go back in level for road use. The lights are non xenon.
Cheers guys
Current:
Porsche 981 S PDK Fully Loaded, beautiful.
Former:
Porsche 911 997.
Audi A4 B7 2.0T FSI S-Line.
BMW E36 318iS Coupe.
Ford Escort RS Turbo Series 2.
Ford Fiesta XR2 MKII.
Martian
2007 Porsche 997 Turbo
PostPosted: Sat Jan 15, 2011 12:36 pm    Post subject: Reply with quote
Yes lights have to come out, an easy job though with the supplied tool in the (small) toolkit.
michelin
PostPosted: Sat Jan 15, 2011 12:44 pm    Post subject: Reply with quote
Thanks for the reply.
I've managed to get one out but the other was very tight so much so that the head of the bolt has sheared off !!! Sad
Any ideas, any help appreciated.
Cheers Martian Thumb
Current:
Former:
Porsche 911 997.
GT4
Nordschleife
Nordschleife
PostPosted: Sat Jan 15, 2011 12:59 pm    Post subject: Reply with quote
5mm socket on slim extender.
http://911uk.com/viewtopic.php?t=56929
http://911uk.com/viewtopic.php?t=54922
michelin
PostPosted: Sat Jan 15, 2011 1:31 pm    Post subject: Reply with quote
I used my own 5mm socket etc and upon trying to turn the bar the 5pm head on the bolt sheared off ! Couldn't believe it.
How on earth do I get light out now?
Help
Current:
Former:
Porsche 911 997.
GT4
Nordschleife
Nordschleife
PostPosted: Sat Jan 15, 2011 1:35 pm    Post subject: Reply with quote
Well I guess you are looking at mole grips or a reverse threaded socket (it is possible that the mounting table can be accessed via the wheel arch liner, but I am not convinced the access will be meaningful).
AFAIK, you need OPC!
By the way, which headlamp side was this (driver/passenger) and what direction were you turning the release tool/socket (CW/CCW)?
michelin
PostPosted: Sat Jan 15, 2011 1:51 pm    Post subject: Reply with quote
It was passenger side and I turned it the opposite direction to the drivers side one. That came out fine.
I'm think of using a 3 or 4mm nut and screwing it onto the thread with hope it will at least release the lamp. Then all I need to do is order a new locking bar.
Hmmmm not happy
Current:
Former:
Porsche 911 997.
bobsan
PostPosted: Sat Jan 15, 2011 2:30 pm    Post subject: Reply with quote
RHD vehicle:
pax side to remove = anti CW, 180deg
pax side to replace = retaining bar relaxed (pointing down) quarter deg. CW
Drivers side to remove = CW 180deg.
Drivers side to replace = retaining bar relaxed, quarter turn anti CW.
Indulge yourself, it's later than you think....
michelin
PostPosted: Sat Jan 15, 2011 6:20 pm    Post subject: Reply with quote
bobsan wrote:
RHD vehicle:
Thanks for the info guys. Having trouble getting a grip on the thread to turn it seeing as head is no longer there Question
Current:
Former:
Porsche 911 997.
monster
PostPosted: Sat Jan 15, 2011 6:34 pm    Post subject: Reply with quote
No the headlamps do not have to come off to remove the front bumper, I did a Gen 2 front and rear conversion to mine not long ago, and the headlamps stayed firmly in place!
 Filesize:  51.76 KB
 Viewed:  12723 Time(s)
 Filesize:  60.6 KB
michelin
PostPosted: Sat Jan 15, 2011 8:22 pm    Post subject: Reply with quote
Ah right thanks. I've removed all necessary bolts and the two black slide clips near the headlamps. Tried getting it off before and no luck, dont want to snap anything, again !!
Is it only held in by the clips near to the headlamps ?
p.s. still have the problem with the sheared bolt. God knows what I will do if one of the lamps fail ??? Dont know
Thumb Thumb
Current:
Former:
Porsche 911 997.
Cunno
PostPosted: Sat Jan 15, 2011 10:01 pm    Post subject: Do headlights have to be removed to remove the front bumper? Reply with quote
Hope this helps. Once you removed all these the bumper should pull off.
Jon.
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
Remove plastic trim around bonnet catch. It just pulls off.
 Filesize:  80.59 KB
 Viewed:  12633 Time(s)
Inside hole is the sliding clip. Need pull out. Bent coat hanger works well
 Filesize:  70.12 KB
Remove 3 screws high lighted in red.
 Filesize:  62.14 KB
In the wheel arches there are three screws to remove. It's easier to do, if you remove front wheel. Small hole should have rubber cap on it. Remove cap and place thin screw driver in it. This will release front indicator clips. Pull out and un plug. This
 Filesize:  101.65 KB
3 or 5 screws under the middle of the car need removing. 1 in center cup others are easy to spot.
 Filesize:  88.37 KB
2 Screws in each corner of Bumper need removing. Just infront of wheels
 Filesize:  56.16 KB
monster
PostPosted: Sun Jan 16, 2011 1:58 am    Post subject: Reply with quote
Hi Michelin, Cunno's reply is an excellent one, he has shown clearly all the different fixing areas, well done that man!! We didnt bother removing the wheels on mine, but that would make the job easier if its your first time!
The sliding clip in his second pic is the one that you would struggle to work out if you were approaching this job without prior knowledge!
Its sounds a lot of trouble to go to in order to clean your rads!, can't you just reach in with your hands and remove any debris!
yes the sheared bolt is probably worth forgetting about until such time as when you actually do need to remove the lamp, chances are you never will!
Good luck!
Pip1968
PostPosted: Sun Jan 16, 2011 9:06 am    Post subject: Reply with quote
Where are the last two bolts (shown in the last picture) situated?
Sorry new to Porsche so just constantly browsing for tip top tips.
Pip
Cunno
PostPosted: Sun Jan 16, 2011 9:38 am    Post subject: Do headlights have to be removed to remove the front bumper? Reply with quote
Pip
Just infront of the front wheels, at the bottom of the bumper.
Under the bumper about here.
 Filesize:  63.71 KB
 Viewed:  11907 Time(s)
michelin
PostPosted: Sun Jan 16, 2011 7:37 pm    Post subject: Reply with quote
Finally got the bumper off. Thanks for all your help guys.
Stil got the issue of getting passenger light out if it fails Dont know
Current:
Former:
Porsche 911 997.
michelin
PostPosted: Sun Jan 16, 2011 7:39 pm    Post subject: Reply with quote
Good luck!
Cheers monster, good man !. Bumpers finally off ! Thumb
Current:
Former:
Porsche 911 997.
michelin
PostPosted: Sun Jan 16, 2011 7:40 pm    Post subject: Re: Do headlights have to be removed to remove the front bum Reply with quote
Jon.
Cheers Jon the info, it helped alot. Good lad Cool
Current:
Former:
Porsche 911 997.
