- Joined
- 15 May 2002
- Messages
- 13,086
This 996 twin turbo engine has been completely rebuilt to 3.8Ltr pushing out 800bhp +/- we have restrained the beast and restricted it to about 680bhp +/- as she was getting too hairy to drive...
[url]www.design911.co.uk[/url]
This is what has been done....
Perfect Bore 3.800cc Barrels & Pistons,
CARRILLO Connecting Rods, CARRILLO Head Stud Kit,
Up rated head gaskets,
Billet Diverter Valves,
Modified Garrett K24 High Flow turbochargers manufactured with special fine balance & tolerances,
ECU Bespoke Software,
DesignTek high -Flow Air Induction System,
DesignTek 41.5 mm Primary Tube Stainless Steel Headers,
DesignTek Silicone Boost Hose Conversion w/ Diverter Valve "F" Hose,
DesignTek high flow coolant radiator kit,
70mm High Flow Turbo Air Inlet Ducts (plastic),
Braided and Fire Jacketed Fuel Line Upgrade Kit w/ Fuel Filter Kit,
Modified Fuel Rails,
High Flow Fuel Injectors ,
Bosch Spark Plugs,
DesignTeK Hi Flow Headers ,
High Flow 100 Cell DesignTek Cat's and Performance Exhaust,
DesignTek Quad Exhaust Tips,
Evo High Spring Load Diverter Valves,
Evo High Flow Ram Air Intake System,
DesignTek Red High Flow Silicon Boost Pipes,
Sachs High Load Clutch Pressure Plate,
Sachs High Load Rigid Clutch Disc & Bearing,
Upgraded high pressure waste gates,
Machined billet aluminium waste gate mounts ..... the list goes on and on
It cost the best part of £30,000 parts and labour to build this engine....
Just finished the Black Matt Vehicle wrap and Fitting 18" OZ Alleggerita HLT Light Weight Alloy Wheels & tyres
Plans for a bespoke leather and alcantara interior and Fitting Roll cage & DesignTek 6 point harness / Bilstein PSS9 Suspension & set-up
This car is like a "YORKIE" bar IT'S NOT FOR GIRLS !
Bosch Spark Plugs,
