997 : 2004- 66
996 : 1997-2005 35
964 : 1989-1993 1
Niall McMahon
PostPosted: Mon May 17, 2010 12:55 pm    Post subject: Peter Morgan or Porsche Inspection? Reply with quote
Do i arrange a Peter Morgan independent inspection or have the car taken to Porsche? The car has an extended Porsche warranty and full Porsche service history. The advantage of the second option is that they will then be able to immediately fix anything wrong there and then. The owner has said that anything uncovered by either inspection will immediately be fixed under the terms of his extended warranty but might Porsche make more of a fuss if PM finds the fault rather than them?
Any advice welcome. Cost isn't a factor.
Maxie
Yas Marina
PostPosted: Mon May 17, 2010 1:36 pm    Post subject: Reply with quote
Porsche doesn't need to know that PM found the fault do they? The owner could pass it off as a discovery of his own I'd imagine.
Other alternative would be for you to pay for a 111 point inspection at an OPC and see what the outcome is.
~ Maxie
Question
Currently Porscheless, 2018 BMW 640d M Sport +
Niall McMahon
PostPosted: Mon May 17, 2010 2:22 pm    Post subject: Reply with quote
The 111 point inspection is what I mean I think (is there another kind Porsche do?) - I've heard an independent inspection is better than those?
Maxie
Yas Marina
PostPosted: Mon May 17, 2010 2:31 pm    Post subject: Reply with quote
Indeed, a PM inspection will be more detailed than an OPC 111pt check and that's reflected in the cost of doing one of these as well.
If you did a 111, then I can't but help get the feeling that it will be passed off as an ok car.
~ Maxie
ResB
Estoril
PostPosted: Mon May 17, 2010 2:33 pm    Post subject: Reply with quote
There will be items for sure than PM will pick up that isn't covered under the extended warranty anyway, but at least "you'll" be able to do something about them in your own time.
When you take it to the OPC for "any" warranty items to be rectified, which may include items the OPC may miss (which they do) you may also be able to get the OPC to remedy any non warranty items at the same time and possibly FOC. Dont know
I see dead pixels.
Niall McMahon
PostPosted: Mon May 17, 2010 3:15 pm    Post subject: Reply with quote
Worth a try.
Ok, I've chosen Peter so we will see what happens. I am hoping he will find nothing at all wrong - does that ever happen? Doubtful I guess. The seller himself (who, to be fair, is most certainly a decent and honest man) is 100% convinced it is perfect. We'll see...
spyderman
PostPosted: Mon May 17, 2010 7:11 pm    Post subject: Reply with quote
FWIW a 111-point check on my Boxster last year did not reveal a dead bird stuck to the radiator that within a month led to my air con condenser failing - which was not covered by my 3rd-party warranty. Cost me another £430 to have that fixed - would have been £600 had I let the dealer that missed the bird in the first place do it.
2004 Boxster S 550 Spyder Anniversary Edition
theogeor
2006 Porsche 997 Carrera 2
PostPosted: Mon May 17, 2010 7:58 pm    Post subject: Reply with quote
Just a note on the differences
The 111 Point Checks is done in a Garage thus having access to a ramp etc so you are able in theory to have a better look at the car
The other type of inspections are done on site so for whoever is checking the car is more difficult to have a detailed check of the car as they have little aids with them and it give more emphasis on the paper work of the car as well as obvious defects
I would personally go for a different approach and have the car checked at an interdependent Porsche specialist that they will have access and ability to check the whole car. In general I have seen as stated obvious things that have been missed in a 111 PI as well also I have witness reports from various specialists that were very ambiguous and did not worth the money spend on them
Regards
Theo
911 997 C2 56 Reg
B180 SE 14 Reg (family car)
406 Coupe (Now in Cyprus as a holiday car)
A160 Blueefficiency Avantgarde 11 Reg (second holiday car in Cyrpus)
Niall McMahon
PostPosted: Mon May 17, 2010 8:02 pm    Post subject: Reply with quote
At the moment, Peter and the seller are having difficulty arranging an appointment. Peter himself actually recommended an independant garage if all else fails (Jaz in London) and as the seller has receipts from there I doubt he would object to that one.
Question: does the 111 check include a reading of the ECU/DME or a test drive? If not it's definitely not enough.
ResB
Estoril
PostPosted: Mon May 17, 2010 9:05 pm    Post subject: Reply with quote
Mark from Stirlings posted a 111 point inspection form somewhere on this forum, but I can't seem to find it.
I see dead pixels.
wagonface
1991 Porsche 964 Turbo
PostPosted: Tue May 18, 2010 7:09 am    Post subject: Reply with quote
Having had a 111pt OPC inspection and also a Peter Morgan inspection I would choose a well respected Indy any day over those two. Should be cheaper than PM, should be more comprehensive and honest than OPC, and will put things into context for you (which PM doesnt). Jaz have a good reputation - why not try and get it done there? Just tell them a (little) white lie that they beter do a good job because you will use them for servicing, and that should keep them on their toes. Good luck.
964 3.3 Turbo
ex: 996 C2 Cab
Niall McMahon
PostPosted: Tue May 18, 2010 10:21 am    Post subject: Reply with quote
That's what I am going to do. Thanks for the advice folks.
bakumackem
PostPosted: Tue Oct 06, 2015 10:02 am    Post subject: Reply with quote
Hi
go easy as I am new to this forum, and new to Porsche ownership.........infact to date I am a confirmed bike man!
That said I am considering going into the deepend on a 2005 Turbo S Tiptronic; deposit paid, going through the pre-checks on it.
I want to be sure it's not got any hidden horrors so I am doing the following 3 things:
1. arranging for a friend who is a Porsche owner and a keen racer to test drive for me
2. arranging for an inspection..............
3. will test drive myself assuming positive response to points 1 & 2.
I am considering using PM, but note the previous posts propose a better way is to go with an independent Porsche specialist.
Any recommendations for the Coventry area?
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Oct 06, 2015 10:45 am    Post subject: Reply with quote
Good luck with the purchase- I think I've seen an ad for that car, if it is at a Coventry indy... looks great!
No harm in getting someone else to drive the car- keep an ear out for suspension creaks at low speeds, many which only manifest after a relatively long drive, 1/2 hr at least. Make sure you hear it started from stone cold.
Shirleys in Meriden are good, if you want a second opinion.
flying_scotsman
2010 Porsche Boxster 987
PostPosted: Tue Oct 06, 2015 10:49 am    Post subject: Reply with quote
Coventry - try PCT.
Welcome to the forum BTW. Mods may prefer that you start a new thread.
Current: 2010 987 (Gen 2) Boxster PDK
Ex: 1990 964 C4
Ex: 1997 993 Targa
Ex: 2006 987 Boxster S 3.2
JH
PostPosted: Sun Oct 11, 2015 8:39 pm    Post subject: Reply with quote
I looked into all this myself recently and went with a well established independent who was located very close by to the seller. I was really pleased with the service. One of the advantages of Peter Morgan of course is that he will travel to the car and most can't do that. He isn't cheap in part because you pay for the travel time. I was extremely impressed with the independent specialist I used and think that if I was doing it again then that will be my preferred route. If for logistics it is not possible to take the car to an indie then I'd use someone like Peter Morgan if he covered the area. Third choice would be OPC. Not that they are bad, it's just that it seems to be more of a box ticking exercise, the checks are not that detailed, and you don't tend to know who will be doing the check.
