Oil Pressure gauge 2000 C2.....Newbie advice
adamw
Portimao
9 Jul 2009
4,339
Can anyone shed any light on normal behavior for this gauge?
IE:
Pressure started from cold
Pressure on idle
Pressure at certain points in the rev range.
Just got my 996 & I want to make sure I am reading this properly so that if there is a problem I spot it.
Thanks in advance :thumb:
Adam
Cold start any revs: full pressure 5 bar
Fully warmed operating temp at idle: lowest running pressure 1.8/1.9 bar (<2 bar)
Fully warmed operating temp at steady 5k rpm: 3.5 bar AFAIK (check your handbook / manual)
Fully warmed operating temp full acceleration to 7+k rpm: 5 barish
Thanks mate.
This sounds about right to what I have experienced so far.
I did look in the manual, but I could only find a section that reffered to:
I couldn't find anything in reference to idle cold, idle warm or acceleration.
I was just a little supprised when it read "full pressure 5 bar" on cold start yesterday :?
But now I know that is the norm it's all good :thumb:
Adam
I remember that being a concern to me when I got my first 911. All perfectly normal :thumb:
I've seen as low as 1 bar at idle after some really serious driving, back to back laps on the ring etc
It's more about a constant than a one off reading, so long as it's not doing anything different from normal then all should be okay
That is why I only mentioned handbook/manual against the third of the four scenarios.
The car needs/creates full pressure at startup because it has to lubricate the entire engine immediately. This is as close as it can get.
The other factor is that the oil is at its most viscous at cold (and hence pumping requires/results it high pressure).
This scenario would the opposite to cold startup as the engine would be at its hottest (past average operating temp level) and hence the oil would be thinest and lowest pressure at idle. Additionally, the engine may be looser due to heat expansion.
The <2 bar test at idle is a good indication that the engine has fully reached operating temp and the fun can begin. In normal road conditions you would be hard pressed to recreate 1 bar though.
I guess individual pressures will also depend on the oil grade used in the engine (ie 0W-40, 15W-45, Tesco own brand :-o )
Also how worn the engine is (a 100k engine with worn bearings and pump etc will have lower overall pressure than a new, tight engine)
Cheers Dave :thumbs:
Thanks for all that. All very useful info :thumb:
More useful than the manual :D
124,533
1,441,249
48,944
Spider69
