Right, seeming as there has been a few issues with the 997's recently I thought I'd re-vitalise an old issue I have had with mine, for perhaps a year now.
It's an incredibly long story so I'll cut to the chase.
My issue appears to be related to either the clutch, gearbox or drive shaft IMO. When I change gear and on release of the clutch pedal (near the top) I get a thump from what appears to be just behind me. It feels like something is engaging too suddenly, snatching almost and it hasn't got that cushioned, smooth feel to the gear change. It does it in all gears, perhaps meaning it's not a specific gear issue, therefore it would indicate to me it that it is something quite fundamental, perhaps even simple!
However, the OPC have 'apparently" changed what they thought was a problem with the 'Dual Mass Flywheel". Seemed like we were onto a winner with that one but alas not as the problem still persists.
Further investigation took the OPC down the clutch route, again replacing what was thought to be the offending item. Again, the problem is still there.
I should say, this problem all of a sudden started to happen and was significant for me to notice a change immediately, taking into consideration that I drove it every day.
The symptoms are even more apparent when in Sport mode. Because the engine/throttle is slightly more responsive it makes the issue worse/more noticeable. What I will say is that when your 'really, on it and shifting gear like your life was on it" the knocking isn't actually noticeable for some reason
After 4 visits to the OPC it was left as a logged issue should anything catastrophic go wrong.
Anyway, this morning, I had stopped at a set of traffic lights, only to be left with a gear selection issue. (It is possible they are unrelated, but my gut tells me they are not as I have noticed that gear selection has got a little worse over the last few weeks). Anyway, I couldn't get first for the life of me, no matter what I did, putting it in neutral, letting the clutch out, depressing it once again etc. In fact I was on a hill and took the opportunity to let the car roll backwards in an attempt to get the elusive first gear but alas not. Eventually, on the second light change I found the gear, (it was there all the time!) and went on my merry way albeit fairly embarrassing!
I'm organising another visit to the OPC to pick up where we left off 6 months ago but I'm not holding out for much luck for some reason. There is definitely a problem though.
One issue that wasn't present before was that, if you approach a junction/traffic lights and you are dropping down the gears as you do, when you stop you'll find your most likely to be in 2nd. If, whilst stationary and whilst the clutch is depressed and in 2nd gear, I change into neutral and let the clutch out, as I release the clutch I get the thump at that point.
Can anyone offer any suggestion or perhaps let me know if their car does the same thing.
