997 : 2004- 71
996 : 1997-2005 36
Boxster : 1997- 25
theredtr6
PostPosted: Fri Dec 26, 2008 7:45 pm    Post subject: 997- Sports Exhaust and Cruise Control question Reply with quote
New to this forum and I can see there's a wealth of experience and info available from the membership, wonder if you can help me with a couple of questions;-
A 997 fitted with sports chrono pack but std exhaust- to have a Porsche switchable sports exhaust fitted will it be straightforward exhaust fit only ? ie will any wiring/relay's whatever already be fitted but just require connection? Rough cost for this? any ideas?
Also regarding Cruise, does the 997 have all the wiring etc fitted and is it a straightforward fitting of stalk or is more required estimation re costs?
Thanks for any guidance
Steve
TDK
PostPosted: Fri Dec 26, 2008 8:43 pm    Post subject: Reply with quote
The wiring to switch the PSE is not fitted as standard, even if you have the Sports Chrono pack. Your OPC will relieve you of approximately £1600 in order to fit a PSE for you, including wiring it into your Sports switch.
I took the alternative approach and bought a PSE from eBay for £500 and fitted it myself. I too have the Sports Chrono option, but decided I wanted the noise all the time (like many people on here) and didn't bother wiring the exhaust in at all.
As for Cruise - yes it can be retro-fitted. You can either pay an independent specialist to do it for you or do it yourself for just under £400. Full details here... http://www.renntech.org/forums/index.php?showtopic=17623
Simon.
theredtr6
PostPosted: Fri Dec 26, 2008 9:25 pm    Post subject: Reply with quote
Simon,
Thanks for your help..
Steve
