997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
johnnycool
PostPosted: Mon Jun 30, 2008 9:43 am    Post subject: speedo removal Reply with quote
hi , need to remove the speedo from my 1987 930 turbo , anybosy got and tips on this or the best way to remove it ? I need to mark it up in kph for the mot on saturday !
thanks for any fast responses !
just got the car on saturday ! its sweet ! Thumb
1987 930 factory flatnose - black on black
many many engine mods Smile -RIP 11/10/09 :-(
1988 Turbo Targa 29k miles -SOLD !
1991 3.3 T Black/Black techart bits, HKS EVC, decat, Innovate wideband
johnnycool
PostPosted: Mon Jun 30, 2008 10:00 am    Post subject: Reply with quote
does this thing just pull out ? or anre there any screws behind ?
Surprised
pete917
1974 Porsche 911
PostPosted: Sun Sep 14, 2008 10:12 am    Post subject: Reply with quote
They just pull out. They are held in place by a tight fit into a rubber surround gasket. The wiring loom beghind the speedo is quite short so dont pull it too far too quickly.
Computamedic
1989 Porsche 964 Carrera 4
PostPosted: Sun Sep 14, 2008 3:29 pm    Post subject: Reply with quote
As above, they just pull out. It is held in place by a rubber ring, in common with the rest of the instruments.
BTW, there is no need to mark up the speedo with anything. The MOT doesn't require MPH markings - it just needs a working method to display the speed. My car has a KPH speedo and has happily passed the MOT for the previous 4 years without a comment.
Regards
Dave
'89 LHD C4 Coupe (non-factory Turbo-look)
Webmaster at http://www.964uk.com
http://www.computamedic.co.uk/Porsche/
http://www.p-caronline.com/directory/computamedic/
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
pete917
1974 Porsche 911
PostPosted: Mon Sep 15, 2008 2:05 pm    Post subject: Reply with quote
While you've got the speedo out, why not take them all out and upgrade the lights to LED.
I did this for two reasons:
(i) the lighting circuit on the older 911's was not fused and was the cause of many a dashboard fire. The LED's take a fraction of the current; and
(ii) the poor reflectors in the gauges are helped by a brighter whiter light.
Just a thought.....
johnnycool
PostPosted: Tue Sep 16, 2008 3:33 pm    Post subject: Reply with quote
funny you should mention fires as i have already had one while working with the speedo out I disturbed some wires running to the clock and glovebox light , they shorted and went on fire when i turned on the lights!
looks like it had happened before too ! , can't believe no fuse protected this ????
pete917
1974 Porsche 911
PostPosted: Tue Sep 16, 2008 3:35 pm    Post subject: Reply with quote
No there isnt a fuse. You can add one. I have, but then when I upgraded to the LED's the load became almost zero, so the fuse will only work when there's a short rather than too much load so to speak.
