997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Thu Feb 14, 2008 12:05 pm    Post subject: Porsche VIN and Option code Decoder Tools Reply with quote
Click here for VIN Decoder (will open new window)
Smile
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON FACEBOOK
Example of VIN Decoder
 Filesize:  72.46 KB
 Viewed:  6914 Time(s)
GT4
Nordschleife
Nordschleife
PostPosted: Wed Dec 29, 2010 8:31 pm    Post subject: Reply with quote
EDIT: the AutoAtlanta service is currently off-line
If you know your chassis number you can use this database to display all your factory build options (no need to have access to under bonnet or service book VIL sticker):
FULL Porsche VIN Decoder
* OK, not quite FULL as it isn't official and it does have some holes, in which case it just lists the option code, but not the description or the description may be version dependent and the system doesn't know which version of the option you have.
Eg:
My 3.4 996 has the "X51" PowerKit, the system correctly identifies this option, but lists it as the later 3.6 250KW (345BHP) output, whereas it should be 235KW (320BHP) on the 3.4 engine.
My car has "XAD", the system correctly identifies this, but flags it up as an option description not known (it is GT rear fins). In these cases take the code and google or look up here:
http://www.kindel.com/porsche/options.asp
or
http://www.911uk.com/viewtopic.php?t=30179
It also only decodes "physical" options, so cosmetics like colours are not listed.
Just be careful with your "0"s and "O"s, "1"s and "I"s, "2"s and "Z"s, "5"s and "S"s and "U"s and "V"s etc.
Even the DVLA mess that up.
Read direct from the VIN plate (and if different to your paperwork, get it amended).
If in any doubt call or email your local OPC or Porsche GB.
