997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Phil 1319723
PostPosted: Tue Jul 10, 2007 8:18 pm    Post subject: Alignment Reply with quote
Hi, I have an early non-varioram 993 Carrera. I have renewed the standard shock absorbers, front top mounts, wishbone bushes, roll bar drop links, steering arms etc and now I would like to take the car to somewhere that understands the ins and outs of a standard geometry set up. I have been to Paragon and do not wish to return. I used to own an Elise and it was only when I discovered Sinclaire of London that I discovered how it should behave. I really do not want to repeat the process of paying so called experts for incompetence before I stumble across the right people. Why, may you ask, have I gone for standard set up? Well, most specialist manufacturers like Lotus and Porsche do have just an inkling how to do these things and most of the time the modifications I have experienced,,,well..no matter how much I kid myself detract from the original set up (albeit a compromise). I also live in Sussex, the land of rubbish road surfaces. Hopefully someone out there knows a specialist who, like Sinclaire of London, will make my car behave like a 993 should. Any suggestions gratefully received.
PolarExpress
Reims
2000 Porsche 996 GT3 Mk1
PostPosted: Tue Jul 10, 2007 8:19 pm    Post subject: Reply with quote
Hi and welcome to 911uk! Very Happy
South of the river : head for Parr in Crawley
North of the river : head for JZM in Kings Langley, Herts
Phil 1319723
PostPosted: Tue Jul 10, 2007 8:26 pm    Post subject: Reply with quote
Hi, Parr in Crawley it is then if no one else has any suggestions and thanks for the welcome.
Martyn1
PostPosted: Tue Jul 10, 2007 9:18 pm    Post subject: Reply with quote
Alternative
Tognola in Datchet has the equipment for four wheel alignment, had mine done there.
01753 545053
993 Targa / 1996 LHD / Silver **SOLD**
Back with a 997C2S GT silver
Used Porsche
Watkins Glen
PostPosted: Tue Jul 10, 2007 11:22 pm    Post subject: Reply with quote
The 993 has a special rear suspension - it dynamicaly changes angles during operation and needs specialised setup - talk to Jonas at www.JZmachtech.com if they can't do it he will tell you who can.
You must *always* do a four-wheel alignment on a 993. Changes made at one end of the car alone will adversely affect the other axle.
Kinematic toe: an attribute of the 993 rear suspension which helps to stabilize the tail-happy tendency of a rear engine car. The toe value changes dynamically while driving, depending upon the forces acting on the car. This is a critical value, and the vast majority of garden-variety garages will have never heard of this parameter, let alone have the tools or knowledge to address it. Kinematic toe is your litmus test to identify these shops and take your alignment work elsewhere. The factory tools to set the kinematic toe are quite expensive; unless the garage does a lot of 993 alignments, they will *not* have the tools in-house.
After your alignment you should always get a printout of what the actual alignment settings are for your records.
Martyn1
PostPosted: Wed Jul 11, 2007 9:10 am    Post subject: Reply with quote
Tognola have this
Joe M
PostPosted: Wed Jul 18, 2007 7:23 am    Post subject: Alignment Reply with quote
Carrera Performance worth a look too.
993C2S
1997 Porsche 993 Carrera 2S
PostPosted: Wed Jul 18, 2007 8:22 am    Post subject: Reply with quote
Another vote for Tognola here.
Asim
anawaz
PostPosted: Wed Jul 18, 2007 5:17 pm    Post subject: Reply with quote
all around. i think you might find tognola offering this particular service the cheapest.
-ajaz
993 C2 Tip Polar | Blk
993 C2S Man Artic | Blk
Ex - C2S Artic | Blk Manual
RS4 B7 Avant | Violet/Blk
Macan 3.0D PDK | Daily Drive
Porsche
2003 Porsche 996 GT3 Mk2
PostPosted: Wed Jul 18, 2007 9:29 pm    Post subject: Reply with quote
Staines West Side : Head to Tognola
Central : use JZ if you can but it's if just outsdie the M25
East side... not sure !
Porsche on Youtube!
964 Project Car
996 MK2 GT3 CS Manthey
993 Targa
tim993
2016 Porsche Boxster 981
PostPosted: Wed Jul 18, 2007 10:06 pm    Post subject: Reply with quote
has anyone used Camtune in Godalming, Surrey, for alignment work?
cheers
tim
Leosayer
1996 Porsche 993 Carrera 2
PostPosted: Thu Jul 19, 2007 12:44 pm    Post subject: Re: Alignment Reply with quote
I can understand your approach. Any other suspension kit will decrease comfort over the standard set up.
However, Porsche also built in a fair degree of safety into the alignment and a place like JZM have setting which can make the handling characteristics more fun if that's required.
Phil 1319723
PostPosted: Fri Jul 20, 2007 8:59 pm    Post subject: Alignment Reply with quote
Thanks for all your input. Just been put on hold by a leaking rear main seal ..so...clutch etc. Also looks like new 'camber' control arms at the rear as the bushes are allowing noticeable movement and don't look too well. Am I right in assuming that there are no replacement bushes for these? I have already replaced the front bushes with polyflex. Quite easy and comparitively cheap. Anyway I appreciate your input, thanks.
Phil 1319723
PostPosted: Fri Jul 20, 2007 9:06 pm    Post subject: Alignment Reply with quote
Oops, powerflex bushes.
Phil 1319723
PostPosted: Fri Sep 14, 2007 7:43 pm    Post subject: Alignment Reply with quote
Well, it's been a while but alignment done today. The firm I went to were helpful, efficient and above all knew what they were doing. I went to Tognola. Thoroughly recommended.
Andy B Aces High
PostPosted: Fri Sep 14, 2007 7:49 pm    Post subject: Reply with quote
Was going to take mine to Paragon for 4 wheel alignment, did they not do a good job ?
993 Carrera Midnight Blue.
Phil 1319723
PostPosted: Fri Sep 14, 2007 7:57 pm    Post subject: Alignment Reply with quote
Hi, it might be a bit further to go but more than worth it.
angry
PostPosted: Mon Feb 24, 2014 6:24 pm    Post subject: Paragon Reply with quote
Paragon.
Used them in 2012 for geometry (fast road/track set up).
The car now handles brilliantly.
They race 2 964s and regularly win, so must have a good geo guy at the moment!
Dooser
PostPosted: Mon Mar 07, 2016 12:33 pm    Post subject: Reply with quote
I understand that centre of gravity is the place to go, I have to get mine booked in as Jim Reid - or Reid line performance in Aberdeenshire - have screwed mine up and it's eating the front tyres.
It's interesting reading the earlier posts as I think there are some adjustments that they haven't made in the rear.
Hopefully I can get this sorted, however I believe that there is a big waiting list
'94 C2 Polar Silver
cableguy
Watkins Glen
PostPosted: Mon Mar 07, 2016 12:42 pm    Post subject: Reply with quote
CG can usually fit you in within a week or two of calling. Drop Chris or Pete a line and they'll advise the best option.
C.
Pork!
