997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
many
PostPosted: Fri Jul 06, 2007 4:19 pm    Post subject: 996 Technical Service Bulletins (TSB's) Reply with quote
There are almst 200 TSB issued for the 996 and growing, as situations are revealed. Most relate to specific problems, otherwise they resolve any problems via a retrofit or modification. Data via PGB and Renntech.
Updated recently from data from GarethB
TECHNICAL SERVICE BULLETIN INDEX
Customer Recall Campaigns
9901 - A099 - Fuel Filler Cap Seal - Nov 5, 1999
2/03 - A309 - Replacement of Both Front Seats - Apr 23, 2004
1/00 - AY03 - Fuel Level Display: Update of the Software in the Instrument Cluster - Apr 10, 2000
Workshop Campaigns
2/00 - W103 - Rear Engine Deck Lid Corrosion - Feb 9, 2001
6/01 - W201 - Oxygen Sensor Heat Faults/Update DME Software - Nov 2, 2001
5/01 - W205 - Programming New DME - Dec 21, 2001
6/01 - W207 - Checking Rear Muffler - Oct 11, 2002
3/02 - W208 - Update PCM Software - Oct 4, 2002
7/03 - W303 - CDR 23 "Best FM" Functionality - May 23, 2003
2/03 - W310 - PCM2 Software Update - Nov 24, 2003
5/03 - W317 - Replace Key Remote Control - Jun 27, 2003
17/03 - W402 - Replacing Harman Amplifier - May 19, 2004
2/04a - W414 - Updating Software in DME Control UAnit - May 21, 2004
0428 - W415 - Cabrio Rear Window Installation Pliers - Dec 20, 2004
6/04 - W423 - Flat Receptacle of XE Relay Socket - Sep 3, 2004
1/04 - W425 - Replacing Clutch Slave Cylinder - Dec 20, 2004
13/04 - W522 - Updating The PCM2 Operating System and Replacing The 3 - CD ROM Street Map Navigation CDs - Apr 15, 2005
7/04 - W532 - Replacing Air Filter Housing With Element - Apr 8, 2005
7/04 - W545 - Check Crankcase For Proper Machining - Dec 28, 2004
1/00 - 01 - Activating Vehicle Systems With The PST2 - Feb 10, 2000
3/04 - 01 - Spring Strut Locking Device For New Vehicle Transport - Jun 25, 2004
3/02 - 01 - Transport Protection Films - May 31, 2002
7/98 - 03 - Additions/Corrections to Owner's Manual - Jul 23, 1998
4/03 - 03 - OBD II/DME ME 7.2 Manual Supplement 4 - Jul 25, 2003
4/00 - 03 - Oil Filler Cap - Mar 24, 2000
4/97 - 03 - Pre - Delivery Inspection and Activation of PCM - Jul 9, 1998
1/04 - 03 - Return of Control Units and Diagnosable Components - Mar 26, 2004
11/98 - 03 - Vehicle Storage - Dec 3, 1998
10/98 - 0913 - Hardtop and Wheel Storage System - Sep 10, 1998
Group 1 - Engine
12/99 - 1001 - Approved Engine Repairs - Feb 28, 2002
11/99 - 1001 - Oil Leaks/Engine Bolts - Feb 9, 2000
7/02 - 1001 - Option X51 - Increased Engine Performance - Dec 6, 2002
9b/99 - 1001 - Replacement Engines - May 5, 2000
4/04 - 1001 - Replacement Engines - Types M96.03 and M96.03 S (X51) - Oct 22, 2004
1a/01 - 1010 - Crankcases and Bearing Housings - Aug 22, 2003
0201 - 1010 - Power Measurement on a Roller Dyno - May 31, 2002
1/01 - 1310 - Fitting the Piston Pin Circlip - Mar 8, 2002
1/03 - 1359 - Crankshaft Seal - Flywheel Side (R & R Procedures) - Mar 7, 2003
2/04 - 1359 - Engine Oil Leak By Crankshaft Seal (Flywheel Side) - Jul 26, 2004
4/05 - 1359 - New Crankshaft Sealing Ring On Flywheel Side - Sep 6, 2005
8/02 - 1360 - Dual Mass Flywheel Check Procedure - Dec 13, 2002
3/02 - 1363 - Drive Plate Tightening Torque - Jun 7, 2002
10/98 - 1374 - Replacing Crankshaft Seal - Belt Pulley Side - Nov 10, 1998
10/99 - 1379 - Damaged Drive Belt - Jan 20, 2000
9/02 - 1379 - Torn Drive Belt - Proper Documentation For Warranty Return - Feb 14, 2003
10/98 - 1505 - Camshaft/Hall Sensor Rotor Installing - Dec 17, 1998
1/98 - 1546 - New O - ring on Oil Protection Pipe - May 14, 1998
10/00 - 1551 - New Drive Chain and Seal for Inter. Shaft - Nov 10, 2000
4/98 - 1559 - Magnetisation of Valve Tappets - May 14, 1998
2/99 - 1701 - Engine Oil Filling Capacities - Apr 23, 1999
20/07 - 1701 - Overview Of Approved Engine Oils - Dec 21, 2007
1/02 - 1716 - Blue Smoke from the Engine During High Transverse Acceleration - May 10, 2002
8/99 - 1940 - Coolant Expansion Tank - Oct 22, 1999
2/01 - 1940 - Coolant Expansion Tank / Incorrect P/N - Aug 24, 2001
8/00 - 1962 - Spring - Band Type Hose Clamps - Nov 10, 2000
7/00 - 1970 - New Radiators - Jul 21, 2000
Group 2 – Fuel, Exhaust, Engine Electrical System
6/04 - 2005 - Aluminium Look Fuel Cap - Oct 13, 2004
9/99 - 2015 - Carrera 4 - Running Out Of Fuel - Oct 14, 1999
5/99 - 2015 - Fuel Tank Hose Modification - Aug 12, 1999
1/04 - 2066 - Incorrect Fuel level Display In Instrument Cluster - Mar 26, 2004
3/98 - 2454 - Vacuum Lines - Sep 10, 1998
2/04 - 2469 - Check Engine Warning Light Activated In Instrument Cluster - Malfunction Code P2096 and/or P2098 - May 25, 2004
9902 - 2469 - Oxygen Sensor Connections - Oct 22, 1999
8/02 - 2470 - Replacing DME Control Module - Nov 22, 2002
1/01 - 2470 - Tampering with DME Map Data - Oct 19, 2001
6/02 - 2601 - Exhaust System/Sports Exhaust System - May 23, 2003
2/00 - 2601 - Sport Exhaust System - Jun 9, 2000
9/02 - 2634 - Exhaust Tailpipe Rattle - Mar 28, 2003
2/98 - 2634 - Installation of Chrome Plated Tailpipes - Dec 21, 2001
1/99 - 2634 - Tailpipe Shield Corroding - Apr 23, 1999
4/02 - 2706 - Battery Maintenance - Mar 7, 2003
4/00 - 2722 - Cleaning the Engine - Nov 17, 2000
13/99 - 2722 - New Alternator - Feb 10, 2000
4/03 - 2804 - Replacement Ignition Switch - Nov 24, 2003
1/98 - 2870 - Sparks Plugs - Nov 12, 1998
Group 3 - Transmission
2/05 - 3001 - Clutch Pedal Does Not Fully Reach Its Original Position - Sep 6, 2005
2/03 - 3001 - Clutch Pedal Sticks - Oct 24, 2003
1/99 - 3005 - Boost Spring for Clutch Pedal - Mar 25, 1999
2/00 - 3005 - Clutch Pedal Noise - Sep 8, 2000
7/00 - 3041 - Creaking Noise in Clutch Bell Housing Area - Dec 22, 2000
4/05 - 3408 - Short Shift Kit Installation Instructions - Sep 20, 2005
2/02 - 3435 - Analysis of Transmission Damage - Jun 19, 2002
1/06 - 3435 - Approval For Manual Transmission Repair Work - Oct 5, 2006
8/99 - 3639 - Oil Leak From Front Differential Flange Seal - Jan 20, 2000
6/02 - 3701 - Tiptronic Transmission Noises - Feb 14, 2003
5a/99 - 3702 - Approved Transmission Oils - Jun 30, 2000
6a/00 - 3704 - Selector lever Button Pops Off - Apr 5, 2001
1/98 - 3735 - Tiptronic Transmission Replacing - Sep 10, 1998
4/00 - 3848 - Spring - Band Type Hose Clamps - Nov 10, 2000
Group 4 - Chassis
5/00 - 4078 - Loose Stabilizer Bar Connection - Sep 1, 2000
1/99 - 4085 - Noises From Front Springs/Struts - Sep 10, 1999
6/00 - 4085 - Noises In Steering - Aug 18, 2000
2/00 - 4088 - Clicking Noise In Steering - Jun 16, 2000
3/04 - 4407 - Modified Wheel Fastening Bolts - Jun 25, 2004
2/04 - 4440 - Overview of Summer Tires, Wheels & Spacer Rings - May 25, 2004
10/99 - 4440 - Special Model 911 "Millennium" Wheel - Nov 16, 1999
6/04 - 4440 - Summer Tire and Wheel Summary - Aug 10, 2004
1/03 - 4440 - Summer Tires and Wheels (GT3) - Mar 28, 2003
8/04 - 4440 - Winter Tire, Wheel, & Snow Chain Applications C4S - Oct 9, 2004
7/04 - 4440 - Winter Tires & Wheels - Oct 9, 2004
11/01 - 4470 - Brake Booster Seal at Firewall, Changed - Mar 8, 2002
11a/01 - 4470 - Brake Booster Seal at Firewall, Corrected Page - Aug 1, 2002
2/01 - 4502 - ABS - Version 7.0 - Aug 24, 2001
4/00 - 4605 - Brake Pedal Noise - Jul 21, 2000
3/98 - 4605 - Noise From Brake/Clutch Pedal - Sep 11, 1998
4/02 - 4650 - Corrosion on Brake Discs - Jul 22, 2002
1/01 - 4770 - Brake Booster/Spare Parts Requirements - Mar 30, 2001
3/02 - 4834 - Power Steering Expansion Tank - Jun 19, 2002
1/00 - 4895 - Power Steering Return Hose - Apr 21, 2000
Group 5 - Body
5/01 - 5093 - Water Drains in Front Cowl Area - Feb 22, 2002
1/01 - 5302 - Noises in the Rear Seat Well - Aug 24, 2001
6/00 - 5517 - New Microswitch for Front Lid Lock - Dec 22, 2001
1/00 - 5522 - Replacement Lids and Doors - Jul 21, 2000
1/02 - 5717 - Noises in Door Lock Area - Aug 16, 2002
4/99 - 5726 - New Door Latch Striker - Dec 17, 1999
6/98 - 5737 - Inner Door Release Inoperative - Dec 17, 1998
5/98 - 5765 - Door Window Inoperative/Freezing - Mar 15, 1999
Group 6 – Exterior Body Equipment
3/05 - 6006 - Targa Glass Sliding Cover Lift Mechanism Causes Rattling Noises - Mar 31, 2005
5/01 - 6028 - Noises from the New Style Sunroof Frame - Oct 5, 2001
1/03 - 6028 - Tilting/Sliding Roof Noises - Mar 5, 2003
4a/01 - 6040 - New Sun Roof Drive Motor - Oct 12, 2001
4/01 - 6040 - Noises in the Sliding Roof - Oct 12, 2001
2/05 - 6040 - Seal For Targa Roof Sliding Cover Has Been Modified - Mar 7, 2005
12/98 - 6040 - Work on the Sliding Roof - Oct 15, 1998
1b/00 - 6101 - Noises in the Convertible Top - Aug 24, 2001
1/00 - 6101 - Noises In The Convertible Top - Sep 15, 2000
1a/00 - 6101 - Noises in the Convertible Top - Oct 27, 2000
6/00 - 6101 - Parking Brake Switch - Sep 8, 2000
7/01 - 6102 - Noises in the Hardtop - Mar 22, 2002
4/03 - 6110 - Rattling Noises From The Cabriolet Top - May 23, 2003
1/05 - 6117 - Modified Rear Hardtop Locking Mechanism - Feb 16, 2005
1/02 - 6117 - Modified Rear Hardtop Locks - Oct 11, 2002
13/98 - 6119 - Convertible Top Latch Cover Replacement - Mar 25, 1999
3/01 - 6119 - Convertible Top Locking Hook - Aug 24, 2001
3/04 - 6128 - Convertible Rear Window Bonding Loose - Jun 25, 2004
4/05 - 6128 - Return Shipment of Cabriolet Top Covering - Apr 12, 2005
5/00 - 6141 - Convertible Top Side Flap Microswitch - Sep 1, 2000
3/00 - 6315 - Installing Cup Aerokit - Jul 21, 2000
4/99 - 6420 - Noises At The Windshield and Rear Window - Jul 13, 1999
1/99 - 6454 - Modified Power Window Motor - Apr 29, 1999
3/99 - 6475 - Noises At Rear Side Window - Coupe - Jun 24, 1999
16/98 - 6476 - Noises From Rear Side Window - Cabriolet - Jan 26, 1999
9/00 - 6493 - Rear Window Mirror Heating Relay - Dec 22, 2000
14/98 - 6624 - GT Rear Side Skirts - Jul 20, 1999
5/03 - 6658 - Aerokit "Cup II" Installation Instructions - May 23, 2003
4/00 - 6658 - Carrera Rear Spoiler - Oct 6, 2000
4a/00 - 6658 - Carrera Rear Spoiler Purge Fan Wiring - Aug 24, 2001
7/98 - 6692 - Installing Roof Transport System (RTS) (Cabriolet) - Mar 18, 1999
2/97 - 6692 - Installing Roof Transport System (RTS) (Coupe) - Dec 22, 2000
6/03 - 6692 - Roof Transport System - Targa - Apr 25, 2003
19/98 - 6818 - Storage Tray Beneath Steering Column - Apr 23, 1999
17/98 - 6827 - Automatic Dimming Rear view Mirror (Ext.) - Jun 24, 1999
11/98 - 6827 - Automatic Dimming Rear view Mirror (Int.) - Jun 24, 1999
3/03 - 6829 - Illuminated Vanity Mirror - Light Inoperative - Jun 27, 2003
8/00 - 6830 - Cupholder Installation - Nov 3, 2000
1/01 - 6847 - Windstop Locking Peg - Aug 10, 2001
6/99 - 6848 - Oddments Tray Cover - Apr 14, 2000
15/98 - 6923 - Porsche Child Restraint System - Installation - Mar 7, 2000
1/04 - 6924 - Airbag Warning Light Comes On: Fault Codes 45, 46, 48 and 49 - Jul 21, 2004
0201 - 6924 - Seatbelt Buckle Airbag Warning Light - Oct 11, 2002
2/03 - 6959 - New Passenger's Airbag - Jun 27, 2003
6/98 - 6972 - Deactivating Transport Lock - 911 (996) Cabrio - Sep 4, 1998
Group – Interior Body Equipment
2/00 - 7000 - Noise in the Trim Panel Area - Jun 30, 2000
3/99 - 7018 - Cleaning Soft - Look Paint Surfaces - Mar 3, 2000
2/02 - 7018 - Clicking Noises from the Centre of Instrument Panel in the Knee Protector Strip Area - Jul 22, 2002
1/02 - 7018 - Clicking Noises from the Instrument Panel / Passenger's Side - Jul 22, 2002
1/00 - 7018 - Noise in the Dashboard Area - Jun 30, 2000
1/01 - 7031 - Child Seat With Top Tether Attachment Straps - Mar 16, 2001
2a/00 - 7057 - Noise in the Door/Trim Panel Area, A - Pillar - Oct 27, 2000
3/00 - 7059 - Noise in the Door/Trim Panel Area - Jun 30, 2000
2/01 - 7201 - Clicking Noises from the Seat Frame - Sep 28, 2001
12/07 - 7213 - Noise When Electric Seat Fore / Aft Adjustment Is Activated - May 1, 2007
2a/98 - 7231 - Seat Backrest Release Modified - Mar 15, 1999
8/00 - 7239 - Incorrect Programming of Vehicle Keys - Nov 10, 2000
5/00 - 7293 - Lumbar Position Deleted From Seat Memory - Oct 27, 2000
7/00 - 7413 - Seat Cushion is Uneven - Dec 22, 2000
Group 8 – Air Conditioning
2/00 - 8032 - Spring - Band Type Hose Clamps - Nov 10, 2000
2/01 - 8702 - Electrical Plug on Heating/AC Control - Dec 21, 2001
Group 9 – Electrical System
3/99 - 9005 - Suppressor Kit for AM Reception Noise - Mar 25, 1999
1/02 - 9020 - Changing Instrument Cluster - May 10, 2002
8/02 - 9020 - Instrument Cluster Replacement - Dec 13, 2002
3a/99 - 9025 - Instrument Cluster Coding - PSM to ABS - Jul 21, 2000
10/00 - 9025 - Replacement of C4 Instrument Clusters - MY'99 - Mar 30, 2001
9901 - 9068 - Requesting Vehicle Security Codes - Jan 26, 1999
14/01 - 9110 - Coding New PCM Control Module - Apr 26, 2005
8/03 - 9110 - Diagnosing And Repairing The PCM2 System - Oct 20, 2004
13/99 - 9110 - New PCM Control Unit - Mar 31, 2000
15/98 - 9110 - PCM - Exchange Program - Sep 3, 1999
2/99 - 9110 - PCM Cassette Player Noises - Jun 24, 1999
11/03 - 9110 - PCM2 and BOSE Amplifier Spare Parts Requirements - Nov 24, 2003
15/03 - 9110 - PCM2 With Bose Sound System: Sporadic Sound Failure - Nov 24, 2003
3/06 - 9110 - PCM2.0 Control Knob Replacement - Sep 8, 2006
2/06 - 9110 - PCM2.0 Control Unit: Permissible Pixel Errors In The Display - Mar 16, 2006
11/02 - 9110 - PCM2: Start Screen Visible For A Long Time - Feb 14, 2003
10/03 - 9110 - Porsche Communication Management 2 - PCM2 - May 25, 2004
18/03 - 9110 - Wrong Time Indication in PCM2 and Instrument Cluster - Aug 13, 2004
2/01 - 9112 - Failure/Defect of Navigation System - Jul 19, 2002
7/01 - 9112 - New Navigation Drive Unit - PCM 1 Only - Aug 29, 2003
10/02 - 9112 - PCM2 - No Destination Input Possible - Jan 10, 2003
5/00 - 9112 - TrafficPro CD Radio & Navigation Device - Feb 15, 2002
4/02 - 9112 - W209 - Check Navigation Unit (Service Action) - Jan 24, 2003
6/02 - 9120 - Activation of Radio CDR23 - Oct 11, 2002
0201 - 9120 - Radio CDR23/PCM2 Security Code Card - Oct 11, 2002
11/99 - 9120 - Radio Control Knobs - Nov 18, 1999
12/04 - 9141 - Carrera Door Speaker Mount Modified - Dec 15, 2004
12/99 - 9144 - High Performance Audio System - Sep 15, 2000
3/04 - 9155 - Telephone Module (Option I No. 666) - Apr 1, 2004
5/04 - 9160 - CD Changer CDC - 4 Installation Instructions - Jun 25, 2004
1/01 - 9160 - CDR 220 Radio Faceplate Installation - Jul 27, 2001
10/04 - 9184 - Poor Radio Reception - Diagnosis of Antenna Amplifier Possible - Jan 27, 2005
2/04 - 9187 - Preparation For Mobile Phone Installation Instructions (Carrera) - Apr 1, 2004
0401 - 9191 - THB System 8 Telephone Installation Instructions (Sports Cars) - Apr 1, 2004
13/98 - 9210 - Windshield Wiper Relay - Sep 4, 1998
4/98 - 9212 - Installing Rain Sensor - Jan 26, 1999
11/01 - 9212 - Rain Sensor Operation Instructions - Nov 9, 2001
6/00 - 9219 - Checking the Torque of the Wiper Arm - Jul 27, 2000
1/03 - 9227 - Wiper Blade Noise - Mar 7, 2003
7/02 - 9415 - Headlight Ventilation - Nov 18, 2002
4/01 - 9415 - Headlight Ventilation - Apr 6, 2001
5/99 - 9415 - Litronic Retrofit Kit - Nov 11, 2002
1/00 - 9447 - Hazard Light Switch Inoperative - Mar 24, 2000
4/99 - 9498 - Automatic Headlight Beam Adjustment Going Into "Safe Mode" - Apr 23, 1999
1/05 - 9662 - Design Key - Jul 29, 2005
7/04 - 9662 - Insufficient Range of Remote Control - Aug 13, 2004
8/01 - 9662 - Remote Control Indicator Light - Aug 24, 2001
20/03 - 9662 - Replacing The Key Remote Control Battery - Jun 25, 2004
9/04 - 9668 - Installation of After Market Theft Prevention Systems - Sep 21, 2004
5/01 - 9687 - Alarm System Control Unit - Apr 19, 2001
6/01 - 9687 - Extension of Alarm System Functions - Aug 10, 2001
1/98 - 9687 - Programming Automatic Door Locks - Mar 26, 1998
2/02 - 9757 - Holder for Seat Wiring Harness - May 24, 2002
398 - 9801 - Updating the PCM Operating System (Service Action 398) - Apr 23, 1999
rajkumar911
PostPosted: Mon Mar 29, 2010 9:11 am    Post subject: Reply with quote
This is handy. Could you clarify where/how we can get access to these TSBs?
Wattie
PostPosted: Mon Mar 29, 2010 11:24 am    Post subject: Reply with quote
Sorry to be cynical, but considering this was the first post from a new member back in July 2007 (who has never posted again since), I have a funny feeling that the original post may have been moderated to remove an advertisement for OPC / Porsche specialist servicing Grin
rajkumar911
PostPosted: Mon Mar 29, 2010 12:35 pm    Post subject: Reply with quote
Are these available to the general public? Can they now be downloaded from the internet?
Richard H
PostPosted: Mon Apr 12, 2010 6:41 pm    Post subject: Reply with quote
If you become a Contributing Member on www.RennTech.org (about $25 IIRC) then you can download them in read-only format.
