Tiptronic Problems HELP
Andy996
4 May 2007
3
Hi all. Just wanted to introduce myself as a new member. Ghost sent me over after a discussion on Pistonheads.
Just purchased a 1998 996 tip and I'm already experiencing problems with the tip box, which I suspect is quite serious. Would really appreciate any opinions!
It started as a fairly mild blip in 2nd gear. The car pulls away fine, upto about 2500 - 3000 rpm, and then under constant throttle pressure it feels like the car tries to change gear. The revs dip 300rpm or so, you can feel a noticeable 'donk', especially before the car is fully warmed up, and then it resumes normal progress. It really does feel like a gear change, but it definitely isn't. It also only occurs in 2nd gear, always at a similar point rpm/speed, and is much less pronounced when the car is fully warmed up.
So... I took the car to a specialist for a transmission fluid and filter change... nothing else. And it has come back twice as bad as it was. The donk in 2nd is still there, just the same, but in addition it has now started to slip / miss a gear completely!!!
Every now and then at very low speeds, the car will suddenly rev freely for a second, like it's in neutral, and then 'catch' a gear, jerk a bit, and carry on like nothing happened. It has done this two or three times now and I don't feel I can drive the car any longer incase more damage is caused. It feels obviously as if the crank is not connected to the gear box, which I am guessing is something to do with the Torque Converter or valve body. Not sure if Porsches have any friction plates or anything similar which could be slipping without enough oil. When I first left the garage it slipped twice whilst going slowly over speed bumps, so I wondered if it was related to the car being tilted a little starving the torque converter of oil??
It has also stalled once in Drive whilst stationary. I was sat waiting for another car to do a 12 point turn. I was in D, on the brake, and after 30 secs or so the revs wobbled and it just stalled.
Any thoughts or similar experiences anyone?
Yours desperately.
A.
Migration info. Legacy thread was 139183
It certainly sounds like you have problems. When setting off in second gear, the car adjusts torque converter itself, so when you set off it is in a slightly different gear (1st) and as you say you feel the car adjust into 2nd, while all the time showing 2nd on the dash. This however, is very smooth in mine and almost unnoticable (certainly to the passengers).
The stalling also sounds bad. I think this will be an OPC job. I certainly haven't heard anything like this before. SOrry.
Migration info. Legacy thread was 139223
Thanks So poo, that's already more than anyone at OPC could tell me. I did ask the engineer at the OPC several times if it's possible that the car is in 1st from stand still, but telling me it's in 2nd.
Are you sure that's how the Tip systems is suppoed to work?
Migration info. Legacy thread was 139360
Also worth talking to an indi specialist they tend to know more that OPC. Try Paragon?
Migration info. Legacy thread was 139469
I was thinking of going to JZ Machtech tomorrow, I've never used them before but they keep getting recommended to me. Are paragon technically very goog?
The trouble with an OPC in this case I believe is that the only official Porsche service schedule for a Tip box is fluid and filters, new valve body, or new new gearbox. I'm not sure there's any in between with them. I'm convinced this is not a gear box issue, but a smaller component or sub component between the crank and the box, ie the torque converter or something. Not that I really know what I'm talking about!
Migration info. Legacy thread was 139489
124,594
1,441,934
49,026
WilmslowSi
