Ok guys, don't shoot me down but I've got the speakers that I had in my C4S 'hanging' around in the garage, so what should I do with them?
Poon, look away now!
The original, crappy unit, no tweeter. This just isn't good enough!
The tweeter to mount, might require some minor cutting to the original speaker housing ie. make a hole!
The lovely MB Quart 4" unit, mounts perfectly inside the existing aperture...ok will require a ring of Dynamat Extreme to bulk it out slightly.
The whole lot! The separate ring you see is the mounting ring for the MB Quart, this makes it very easy to secure it to the hole. A simple twist and the speaker come off.
I'll do the front over the next few weeks, the trouble is I'm without the stereo, Saffron forgot to tell the stereo know the battery would be disconnected and it's gone into PROTECT, my local OPC couldn't sort it and have sent it to Reading for fixing....Sundeep how's the new Becker going? What connectors does it have on it's rear?
Damian
Migration info. Legacy thread was 133511
Damian
