GT3 - GEO settings
Daniel
2 Feb 2005
12,181
Good Morning all..
I am going to put my new baby in for a GEO, had a chat with PARR and they have said a Stage 1 set up is what I need (30% track and 70% road use), this comes out at £550+vat.
Is this the set up I need ? They do ; Standard - Stage 1 - Stage 2 - Stage 3.
Migration info. Legacy thread was 133342
Previous poster said:
Quote: Originally posted by Daniel on 17 April 2007
Good Morning all..
Well the quick answer is how are you going to use the car? But as I think I know the answer this sounds about right probably similar to JZM's fast road. You really don't want any more than that. BTW that seems pricey compared to JZM. Sure mine was far less than that.
Migration info. Legacy thread was 133346
£650 for a Geo does seem a lot. Guess that is what to expect when you own a GT3 though.
How do you know the geo is not already set for about this anyway?
Migration info. Legacy thread was 133358
I don't !
When I had the car PPI'd, PARR said it could do with a geo, as the tyres are wearing on the inner edge.. And PARR say Stage 1 is what I will need ! I believe she is running standard right now !
Migration info. Legacy thread was 133377
I don't !
I thought when the car was set up for the track that the tyres did wear on the inner edge? :?
Migration info. Legacy thread was 133390
CALLING ADE !
Migration info. Legacy thread was 133398
My rear inners are worn more than the outer. My car was reset to standard geo last year.
They run a certain degree of camber as standard. I think the front cambers are made more extreme with the more track based set ups.
Migration info. Legacy thread was 133401
I don't !
Funnily enough I got just the same from OPC last time I had it in for a service.
"Sir, you should have the geo done as you are showing uneven wear on the tyres"
"Thank you for that, the geo was done 2 weeks ago at JZM"
Uneven tyre wear should not be the only indication that the geo needs doing!!
Migration info. Legacy thread was 133405
Thank Rob...
I need it doing before Bedford, and PARR are the only company that can do it before that date !
Could leave it, and have it done by Manthey at the end of May ??
Migration info. Legacy thread was 133406
I don't know how different the geo settings are from a Mk2 but here's the standard (OPC) settings:
Damian
Migration info. Legacy thread was 133474
I wouldn't mind a copy of JZ's fast road geo settings as i'm way too far away to nip down just for that.
Trouble is they're a bit secretive about the whole thing from what i hear :(
Migration info. Legacy thread was 133475
I suppose one could visit a nice tyre place and get them to print off the settings :roll:
Migration info. Legacy thread was 133479
Here's some more.....
GT3 vs. GT3 RS
2004 GT3
Front axle height: 115 + 5mm (115 to 120mm)
Rear axle height: 128 + 5mm (128 to 133mm)
Front axle:
Toe unpressed (total): +8' ± 2'
Toe difference at 20° lock: -1°30' ± 30'
Camber: -1° ± 5'
Max camber difference, left/right: 10'
Caster: 8° ± 30'
Max caster difference, left/right: 40'
Rear axle:
Toe per wheel: +13' ± 2'
Max toe difference, left/right: 5'
Camber: -1°50' ± 5'
2004 GT3 RS
Front axle height: 113 + 5mm (113 to 118mm)
Front axle:
Toe unpressed (total): +2' ± 2'
Camber: -50' ± 5'
Caster: 8° ± 30'
Rear axle:
Camber: -1°50' ± 5'
Migration info. Legacy thread was 133482
Ok, I've done a little more searching.....
These are the standard Porsche factory settings
Migration info. Legacy thread was 133486
That all means nothing to me..
But thanks anyway..
:D
Migration info. Legacy thread was 133489
124,608
1,442,035
49,038
DD77
