997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
Daniel
2000 Porsche 996 GT3 Mk1
PostPosted: Tue Apr 17, 2007 11:09 am    Post subject: Reply with quote
Good Morning all..
I am going to put my new baby in for a GEO, had a chat with PARR and they have said a Stage 1 set up is what I need (30% track and 70% road use), this comes out at 550+vat.
Is this the set up I need ? They do ; Standard - Stage 1 - Stage 2 - Stage 3.
Confused
Migration info. Legacy thread was 133342
*Current - GT3 996.1 Clubsport (Manthey K400)
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Cayman 3.4 S 987.1
EX Megane R26R #36.
EX Cayman R
Rob J
Paul Ricard
PostPosted: Tue Apr 17, 2007 11:19 am    Post subject: Reply with quote
Previous poster wrote:
Quote: Originally posted by Daniel on 17 April 2007
Good Morning all..
Confused
Well the quick answer is how are you going to use the car? But as I think I know the answer this sounds about right probably similar to JZM's fast road. You really don't want any more than that. BTW that seems pricey compared to JZM. Sure mine was far less than that.
Migration info. Legacy thread was 133346
GT3, RRS, ElanSE
"some of us were born to GT3's the rest of you followed"
Parts
Loser
PostPosted: Tue Apr 17, 2007 11:51 am    Post subject: Reply with quote
650 for a Geo does seem a lot. Guess that is what to expect when you own a GT3 though.
How do you know the geo is not already set for about this anyway?
Migration info. Legacy thread was 133358
http://www.jzmachtech.com/
http://www.porscheshop.co.uk/
http://www.design911.co.uk/default.aspx?source=911uk
Daniel
PostPosted: Tue Apr 17, 2007 12:11 pm    Post subject: Reply with quote
I don't !
When I had the car PPI'd, PARR said it could do with a geo, as the tyres are wearing on the inner edge.. And PARR say Stage 1 is what I will need ! I believe she is running standard right now !
Migration info. Legacy thread was 133377
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Megane R26R #36.
EX Cayman R
Parts
Loser
PostPosted: Tue Apr 17, 2007 12:38 pm    Post subject: Reply with quote
I don't !
I thought when the car was set up for the track that the tyres did wear on the inner edge? Confused
Migration info. Legacy thread was 133390
Daniel
PostPosted: Tue Apr 17, 2007 1:00 pm    Post subject: Reply with quote
Confused
CALLING ADE !
Migration info. Legacy thread was 133398
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Megane R26R #36.
EX Cayman R
Dunc
PostPosted: Tue Apr 17, 2007 1:03 pm    Post subject: Reply with quote
My rear inners are worn more than the outer. My car was reset to standard geo last year.
They run a certain degree of camber as standard. I think the front cambers are made more extreme with the more track based set ups.
Migration info. Legacy thread was 133401
Rob J
Paul Ricard
PostPosted: Tue Apr 17, 2007 1:09 pm    Post subject: Reply with quote
I don't !
Funnily enough I got just the same from OPC last time I had it in for a service.
"Sir, you should have the geo done as you are showing uneven wear on the tyres"
"Thank you for that, the geo was done 2 weeks ago at JZM"
Uneven tyre wear should not be the only indication that the geo needs doing!!
Migration info. Legacy thread was 133405
GT3, RRS, ElanSE
Daniel
PostPosted: Tue Apr 17, 2007 1:22 pm    Post subject: Reply with quote
Thank Rob...
I need it doing before Bedford, and PARR are the only company that can do it before that date !
Could leave it, and have it done by Manthey at the end of May ??
Migration info. Legacy thread was 133406
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Megane R26R #36.
EX Cayman R
Carrera4S
Loser
PostPosted: Tue Apr 17, 2007 4:27 pm    Post subject: Reply with quote
I don't know how different the geo settings are from a Mk2 but here's the standard (OPC) settings:
Damian
Migration info. Legacy thread was 133474
Dunc
PostPosted: Tue Apr 17, 2007 4:30 pm    Post subject: Reply with quote
I wouldn't mind a copy of JZ's fast road geo settings as i'm way too far away to nip down just for that.
Trouble is they're a bit secretive about the whole thing from what i hear Sad
Migration info. Legacy thread was 133475
Carrera4S
Loser
PostPosted: Tue Apr 17, 2007 4:36 pm    Post subject: Reply with quote
I suppose one could visit a nice tyre place and get them to print off the settings Rolling Eyes
Migration info. Legacy thread was 133479
Carrera4S
Loser
PostPosted: Tue Apr 17, 2007 4:41 pm    Post subject: Reply with quote
Here's some more.....
GT3 vs. GT3 RS
2004 GT3
Front axle height: 115 + 5mm (115 to 120mm)
Rear axle height: 128 + 5mm (128 to 133mm)
Front axle:
Toe unpressed (total): +8' 2'
Toe difference at 20 lock: -130' 30'
Camber: -1 5'
Max camber difference, left/right: 10'
Caster: 8 30'
Max caster difference, left/right: 40'
Rear axle:
Toe per wheel: +13' 2'
Max toe difference, left/right: 5'
Camber: -150' 5'
2004 GT3 RS
Front axle height: 113 + 5mm (113 to 118mm)
Front axle:
Toe unpressed (total): +2' 2'
Camber: -50' 5'
Caster: 8 30'
Rear axle:
Camber: -150' 5'
Migration info. Legacy thread was 133482
Carrera4S
Loser
PostPosted: Tue Apr 17, 2007 4:51 pm    Post subject: Reply with quote
Ok, I've done a little more searching.....
These are the standard Porsche factory settings
Migration info. Legacy thread was 133486
Daniel
PostPosted: Tue Apr 17, 2007 5:03 pm    Post subject: Reply with quote
That all means nothing to me..
But thanks anyway..
Very Happy
Migration info. Legacy thread was 133489
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Megane R26R #36.
EX Cayman R
Carrera4S
Loser
PostPosted: Tue Apr 17, 2007 5:07 pm    Post subject: Reply with quote
But thanks anyway..
Very Happy
Get to know it! It's the GT3 secret code Wink
Migration info. Legacy thread was 133491
Dunc
PostPosted: Tue Apr 17, 2007 5:19 pm    Post subject: Reply with quote
It's like looking at the matrix, all numbers and symbols and stuff
Migration info. Legacy thread was 133493
Carrera4S
Loser
PostPosted: Tue Apr 17, 2007 6:11 pm    Post subject: Reply with quote
Well done Neo Wink
Migration info. Legacy thread was 133508
poon
2004 Porsche 996 GT3 RS
PostPosted: Tue Apr 17, 2007 9:08 pm    Post subject: Reply with quote
Dan,
Before you go to Parr, speak to Steve at JZM, they are cheaper (it seems) and alot of GT3'ers use them.
Migration info. Legacy thread was 133591
996RS
poon
Oh and don't tell him that I sent you, or he'll kill me Wink
Migration info. Legacy thread was 133592
996RS
Goto page 1, 2, 3  Next
Page 1 of 3
