Air Con Smell?
Dean Fern
24 Mar 2007
8
Last week or so noticed that when I start the car and air con kicks in there is a dodgy smell for 20seconds or so while the air con settles down. Strange thing is that it isn't every time I start the car. Any ideas?
Migration info. Legacy thread was 131454
Refridgerant leaking into the air stream through an exchanger?
Usually propane or similar is used as refridgerant and it has it's own mild hydrocarbon odour
Migration info. Legacy thread was 131462
Sounds serious. Would this be covered under warranty?
Migration info. Legacy thread was 131464
How would you describe it? Chemical smell or more 'bacterial' smell?
It could be just as simple as getting the system serviced.
Is it still producing lots of cold air?
Migration info. Legacy thread was 131489
Suppose i've guessed at the worst case scenario. Could be something far more insignificant. I would, however, have it looked at by an air-con expert to test for leaks.
Good luck
Migration info. Legacy thread was 131493
Do you use your aircon all the time? Try the following.....just before you reach home switch off the aircon turn the heater to max (HI) and leave it like that for a few minutes until you get home. Ok you'll be bloody hot but it should help with the smell.
Migration info. Legacy thread was 131497
yeah aircon should be ran both hot and cold to get rid of the bugs in there apparently, that includes cold in winter and hot in summer even though its not pleasant.....
Migration info. Legacy thread was 131504
This lot have had a couple or rave reviews in mags if you can be bothered to traipse down to Dorset.
http://www.coolitautomotive.com/
Migration info. Legacy thread was 131505
124,605
1,442,014
49,037
PC Saros
