Porsche Events
Moderator
- Joined
- 23 May 2007
- Messages
- 107
Old forum user Unidentified(11139) wrote:
my drivers side window has a bit of play in it, most noticeable when you close the door, instead of a nice clunk like the passenger side it rattles. If you hold the top of the glass in your hand and wobble it you can feel the play. I presume it's the window regulator so would a simple replacement solve this or is it quite normal for the glass to loosen up after years of opening and closing?
I just like things to be spot on.
I've messed about with the adjusters found under the door, one is for alignment and the other to adjust the closing pressure but the play is still there.
Migration info. Legacy thread was 125166
