Just picked up a 2003 996 c2 (first Porsche!) - its superb, every bit as good as expected but..... the brakes seem hard work. They do work and will stop the car evenly and qucikly, but they need a lot of pedal pressure to get an effect. I also have an EVO with Brembos and std pads and they are much sharper? I expected even std Porsche brakes to be as good as the EVO.The car was serviced 4000 miles back by OPC, its just passed its MOT and has been passed by the supplying dealer who says the brakes are normal and fine. I have had the front wheels off, cleaned everything up a bit and all appears to be working and reasonably clean.Does this sound normal? Are there different grades of pads that are fitted by OPCs Dependant on the owners choice and use? What is best or most common choice to go in std calipers and on std rotors, perhaps to give more bite with less effort - main use is fast road driving .... no track use as such
Migration info. Legacy thread was 122423
