997 : 2004- 78
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 20
Cayman : 2005- 11
Dunc
2000 Porsche 996 GT3 Mk1
PostPosted: Mon Feb 12, 2007 12:13 pm    Post subject: Reply with quote
Warranty work fortunately but had a wee synchro prob and now a MAF. You are correct it is the very chappies old car!
<standsbywaitingnervouslyforhorrorstories>
Migration info. Legacy thread was 116573
rikki griffiths
PostPosted: Mon Feb 12, 2007 12:20 pm    Post subject: Reply with quote
relax!!! Greig fussed & coddled it to death! And, without wishing to insult him, nice guy as he is and had fun with, errrrr, he's no Aryton Senna so the car was driven nicely.
Better?
Re the MAF - u can get ones for 130, but if u OPC it, think it'll cost u circa 400/500 - I know, Ive had 2 fitted!
Migration info. Legacy thread was 116574
Glenn Mc
PostPosted: Mon Feb 12, 2007 12:29 pm    Post subject: Reply with quote
Are you going to do the cooling upgrade too ??
this is meant to be a well worth while upgrade on the MKI so i have been told...
G.
Migration info. Legacy thread was 116576
rikki griffiths
PostPosted: Mon Feb 12, 2007 12:35 pm    Post subject: Reply with quote
G.
Crikey Glenn - the pound notes are flying out of the window Wink
Good q - Ive purchased a set of those brake cooling ducts (ref Andy Duncan), but r u talking about the air vents in the nose like the RS'S, or can u point me in the right direction.
So far, its cup steering wheel, SS kit, those brake ducts, Parr exhaust & package, floating discs and front end respray - does the madness end?!
Migration info. Legacy thread was 116581
Dunc
relax!!! Greig fussed & coddled it to death! And, without wishing to insult him, nice guy as he is and had fun with, errrrr, he's no Aryton Senna so the car was driven nicely.Better?Re the MAF - u can get ones for 130, but if u OPC it, think it'll cost u circa 400/500 - I know, Ive had 2 fitted!
Fortunately mr P is footing the bill for this MAF under warranty. I was in my car round KH with Greig before it was for sale and he seemed to be pretty mechanically sympathetic! I was confident it was a good 'un!
Was looking at the calendar for KH and the only Sunday is that one coming up this month - which i can't make. I take it that the hot marques Sundays are fairly regular and they've just not put the dates up yet? I'm eager to get the car out now!
Migration info. Legacy thread was 116582
rikki griffiths
PostPosted: Mon Feb 12, 2007 12:43 pm    Post subject: Reply with quote
Quote: Originally posted by Dunc on 12 February 2007 Warranty work fortunately but had a wee synchro prob and now a MAF. You are correct it is the very chappies old car!
Better?
Quite regular - 25th next Hot Marques? Next KH date after this I've got (or rather next one Id choose to be at & comfortable with standard of driving & cars that is) is Friday 6th April evening 6 till 8. Quite a good date as its a bank holiday which means I@m nice & relaxed when I arrive. Organised by Dreadnought - do u want more details???
Migration info. Legacy thread was 116587
PolarExpress
Loser
PostPosted: Mon Feb 12, 2007 12:49 pm    Post subject: Reply with quote
G.
The brake cooling conversion on the Mk1 is excellent. It is more than just the Cup ducts that Andy Duncan refers to. It consists of closing up the front underside vents, routing piping through the rear of the inner front wheel arch, and directing it towards the back of the brakes. It's hard to see the full install, but you get this additional scoop inside the wheelarch...
Maximum brake cooling is provided by combining both the brake cooling conversion + Cup brake ducts. I have had both conversions done, and even on a short circuit around Brands Indy, the brakes cooled down enough to actually start squealing again on each lap with moderate brake use.
The vents on the top of the front PU a-la-RS is a different conversion. That is the Cup rad conversion which cants the front rad forward to allow air to hit the rad at a perpendicular angle and vent up and over the front bonnet. Note that the RS does not cant the rads forward and only has the PU vents. Combined with the closed underside vents (see above) and you get cooler running temps and also greater front end downforce. This conversion runs my car at least 10deg cooler at any point in time, and on track days running in max attack mode, the temp never rises above the 80 mark. The difference in front aero is noticeable with a front that feels nailed down at high speed (+17kg front end downforce at speed).
Migration info. Legacy thread was 116588
rikki griffiths
PostPosted: Mon Feb 12, 2007 12:52 pm    Post subject: Reply with quote
thanks OC - Im off for a look now!
2 minutes ago the momo steering wheel from Carnewal turned up _ is a thing of beauty.
Migration info. Legacy thread was 116589
PolarExpress
Loser
PostPosted: Mon Feb 12, 2007 12:55 pm    Post subject: Reply with quote
The Cup steering wheel IS a thing of beauty. Really transforms the feel of the driving experience. Smile
Although I recommend driving with gloves now to avoid sweat flattening the suede!
Migration info. Legacy thread was 116590
rikki griffiths
PostPosted: Mon Feb 12, 2007 12:58 pm    Post subject: Reply with quote
Good point _ Im going to brush the suede right now but gloves are the strategic answer. you, Sir, are a bad influence Wink
Migration info. Legacy thread was 116593
PolarExpress
Loser
PostPosted: Mon Feb 12, 2007 1:04 pm    Post subject: Reply with quote
These are the top variety: inside out (for maximum sensitivity) FIA approved Porsche motorsport ones...
Migration info. Legacy thread was 116597
rikki griffiths
PostPosted: Mon Feb 12, 2007 1:07 pm    Post subject: Reply with quote
Stop tempting me!!!
Im off for me lunch while I can afford it!
Migration info. Legacy thread was 116598
PolarExpress
Loser
PostPosted: Mon Feb 12, 2007 1:10 pm    Post subject: Reply with quote
it's worth it... just suck air and go on the "lightweight" option... Twisted
Migration info. Legacy thread was 116600
Dunc
PostPosted: Mon Feb 12, 2007 1:31 pm    Post subject: Reply with quote
That's a day i can make, i'll send you a pm.
Migration info. Legacy thread was 116606
Dunc
PostPosted: Mon Feb 12, 2007 1:36 pm    Post subject: Reply with quote
Does that mean that you have to wear gloves all the time, even when nipping down the shop for a paper??!! Wink
Migration info. Legacy thread was 116610
rikki griffiths
PostPosted: Mon Feb 12, 2007 2:47 pm    Post subject: Reply with quote
OC said -
"The brake cooling conversion on the Mk1 is excellent. It is more than just the Cup ducts that Andy Duncan refers to. It consists of closing up the front underside vents, routing piping through the rear of the inner front wheel arch, and directing it towards the back of the brakes. It's hard to see the full install, but you get this additional scoop inside the wheelarch..."
Thanks OC _ where did u get this kit from. Ive been on Carnewal looking at brake cooling, but the kit there seems different to what you pasted?
Thanks for the help here & to Glenn for original post.
Migration info. Legacy thread was 116647
PolarExpress
Loser
PostPosted: Mon Feb 12, 2007 3:03 pm    Post subject: Reply with quote
OC said - "The brake cooling conversion on the Mk1 is excellent. It is more than just the Cup ducts that Andy Duncan refers to. It consists of closing up the front underside vents, routing piping through the rear of the inner front wheel arch, and directing it towards the back of the brakes. It's hard to see the full install, but you get this additional scoop inside the wheelarch..."Thanks OC _ where did u get this kit from. Ive been on Carnewal looking at brake cooling, but the kit there seems different to what you pasted?Thanks for the help here & to Glenn for original post.
I had mine done by Manthey. JZM also do the conversion as a combined package with the front PU.
http://www.jzmachtech.com/shells/tuning_product.php?porsche=996&model=996%20GT3%20Mk1%20Air%20Con&engine=3.6&year=1999&id=8164
Migration info. Legacy thread was 116658
PolarExpress
Loser
PostPosted: Mon Feb 12, 2007 3:06 pm    Post subject: Reply with quote
Only if popping down to the shops breaks a sweat! Very Happy
of course, you could always pick the newsagent in the next village Wink
Migration info. Legacy thread was 116661
Goto page Previous  1, 2
Page 2 of 2
