I have issue with the locking/unlocking with the remote keys. '99 C2. I changed the key batteries myself and it improved one but not sorted. Now that key that worked occasionally has packed up. There is red LED activity BUT it will not arm/disarm/lock the car remotely so if you lock (manually) with the key when you unlock the alarm kicks in again !! I even have to hit the lock button on the dash several times to get the passenger door, fuel cover and front & rear bonnet/boots released.
As I work occasionally in Reading, I left it with Porsche UK Reading, their thoughts are they "think" I need new ones ? and maybe control unit (ouch why so expensive !!)
I also heard from an engineer at Reading about some elaborate on/off on/off RESET method and also there's a button on the 'B' post to open the doors etc if the battery is completly shot. It is due back to JCT Sheffield (OPC) to investigate if they have any other excuses (sorry I mean solutions) I'll let you know. ---
Anyone had similar ??
Bloody electronics... they should stick to nuts & bolts !!
Migration info. Legacy thread was 105815
