Porsche 911UK Forum
Is this what i need?
Porsche Events
Moderator
23 May 2007
107
Old forum user Unidentified(11139) wrote:
is this the converter cable i need to get line out from the CR22 for an amp?
/images/migration/UploadedForumImages/16_1_b.JPG(1).jpg
/images/migration/UploadedForumImages/a5_1.JPG.jpg
Migration info. Legacy thread was 84157
have you taken out the unit to have a look at the back ?
Migration info. Legacy thread was 84189
yes, I also had a look in the user guide which has an illustration of the back. The yellow plug above looks like it will fit, same pins, same arrangement but the actual plug on the back of the unit is one big one.
Migration info. Legacy thread was 84221
that's all I ever did... you find a matching pair then you're good to go !
Migration info. Legacy thread was 84227
That sure looks like the correct one.
I received mine today too , with the speakerline out-put plug aswell.And the unit release tools....
Migration info. Legacy thread was 84254
Yes, correct lead for amp. The reason the plug looks small compared with the socket on the set is that the same socket is used for a CD changer.
Migration info. Legacy thread was 84382
just one thing now that i know it's the right cable - on the back of the stereo the upper plug is one large plug which covers all pins, this converter cable is meant to plug into the same position but to the left and only occupy 6 pins, do i need to cut the large plug? Have a look at the pic below -
/images/migration/UploadedForumImages/PDRM1686.jpg
See the red plug, the right side has a divider line so i presume i cut it here
Migration info. Legacy thread was 84446
124,354
1,439,460
48,712
golfguy11800
