997 : 2004- 59
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
GJL
PostPosted: Mon Aug 07, 2006 3:09 pm    Post subject: Reply with quote
Hi Guys
My oil gauge doesn't float up even after a long run and the dipstick looks low. It is some time to the next service. Is it straightfoward to top up the oil? (do you just pour down in the tube?) What oil do you use?
Also - does anyone else get a really hot cabin when driving?
Migration info. Legacy thread was 68636
Fuchs
Shanghai
1994 Porsche 993 Carrera 2
PostPosted: Mon Aug 07, 2006 3:16 pm    Post subject: Reply with quote
Previous poster wrote:
only if i have the heating on - Wink
serious part now - topping up the oil should be a doddle - get the engine up to operating temp, keep the engine running, park on a flat surface and add a small amount at a time, checking the dipstick after each amount is poured.Maybe check your handbook as well to see if there are any tips relating to your model.
Migration info. Legacy thread was 68638
1994 Carrera 2
Ex 1984 Carrera 3.2
GJL
PostPosted: Mon Aug 07, 2006 3:21 pm    Post subject: Reply with quote
The manual that I have doesn't actually say anything about how it's done! It wouldn't have occured to me that it had to be done with the engine warm and running, so thanks for that.
I get a lot of heat coming out from right hand side of the drive shaft tunnel and under the glovebox, have to drive with the aircon on the whole time to cope!
Migration info. Legacy thread was 68641
Fuchs
Shanghai
PostPosted: Mon Aug 07, 2006 3:28 pm    Post subject: Reply with quote
sounds like you have a heating vent on even when it should be closed - at your next service maybe get them to check it out for you.
Migration info. Legacy thread was 68643
1994 Carrera 2
Ex 1984 Carrera 3.2
Porsche
2003 Porsche 996 GT3 Mk2
ditto from what Fuchs has said...
as for the hear problem.. could be anything, you may be missing a heat sheld or a fualt with the air con, i.e. heat mixers no set properly, etc etc
Migration info. Legacy thread was 68644
Porsche on Youtube!
964 Project Car
996 MK2 GT3 CS Manthey
993 Targa
supersport
1987 Porsche 911 3.2 Carrera Supersport
PostPosted: Mon Aug 07, 2006 3:29 pm    Post subject: Reply with quote
The heating one is interesting, I was in the passenger seat of my 3.2 the other weekend and noticed the same thing. Obviously when it is dead hot, and you don't have aircon, this is a crap state of affairs.
Had the car check on friday and the flapper boxes in the rear were open and working correctly. However, the passenger side fan is dead. Unless there is some electronic component that has gone hay wire and turning the heating on and off, I am guessing that as the fan is dead, it is letting hot air through into the cabin.
Even though the flapper boxes are open to vent hot air out into the world, there must be an amount of air that still travels down the pipes into the cabin. It is noticeably better when the car is moving.
Maybe you have either a similar problem, or your flapper boxes are sticking in the closed position, ensuring that you get hot air in.
Of course it also doesn't help with hot oil pipes running down the side of the car, I have noticed that these things are pretty warm places to be anyway.
Migration info. Legacy thread was 68645
Mark
1987 911 Carerra 3.2 Supersport
Fuchs
Shanghai
PostPosted: Mon Aug 07, 2006 3:48 pm    Post subject: Reply with quote
i had the flapper boxes go permanently closed on my 3.2 2 weeks after i bought it, just as winter was beginning - couldnt get it fixed for 2 weeks so had to drive to work looking like a yeti - much to the amusement of my collegues - but it was an easy fix......
Migration info. Legacy thread was 68651
1994 Carrera 2
Ex 1984 Carrera 3.2
Daniel
2000 Porsche 996 GT3 Mk1
PostPosted: Mon Aug 07, 2006 3:53 pm    Post subject: Reply with quote
Hi Guys
Can you go by the oil float on the dash as a good idea of how much oil the engine has ? Mine only just comes off the red following a long ish drive !
Dan
Migration info. Legacy thread was 68652
*Current - GT3 996.1 Clubsport (Manthey K400)
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Cayman 3.4 S 987.1
EX Megane R26R #36.
EX Cayman R
