997 : 2004- 65
996 : 1997-2005 33
Cayman : 2005- 22
Macan : 2014- 8
F1_Dragon
2002 Porsche 996 Carrera 4S
PostPosted: Sat Mar 25, 2006 6:12 pm    Post subject: Reply with quote
Hi All,
Washed the car this morning and took her for a short spin to dry out the brakes. 2 hours later went to start her up and she wouldn't turn over, battery gauge just above 10V Sad
Phoned Porsche Assistance (aka RAC) who turned up in 40mins from me making first call. Laughing
Alternator ok, so new battery probably needed. Went for a long blast to try and get some charge in to it, the battery gauge reads around 13.5V, have to see tommorrow if this is held.
Assuming i do need new battery...where should i get one from, I am based in North West London?
The RAC guy said i should get battery from OPC as they are gel filled and only Porsche supply these. Given i also want to preserve my warranty and need Porsche parts to to do this, do people think this is the best (if pricy) option?
as always any thoughts appreciated...chrs!
Migration info. Legacy thread was 50851
Haran
996C4S
Used Porsche
Watkins Glen
PostPosted: Sun Mar 26, 2006 12:23 am    Post subject: Reply with quote
Do a search on battery! there is so much on here - every 993 drains batteries - get a spare and keep it charged - dont buy a OPC at 120 quid - get a Bosch silver for less than 60 - even get two!
example from one of my previuos posts.../...
"Batteries dont like 993's. There is a current drain which causes them to go flat in a few days. Clock and alarm system are the culprits. Thats probably why Porsche charge 120 quid for a battery - it helps to keep the parts dept profits up.
My car has a battery disconnect switch installed by a previous owner. If you dont use the car every day for a decent drive the battery gradually discharges to the point where it damages the cells. If you have a garage with power you can get a mains fed battery maintainer to keep it in tip top nick.
I would be inclined to run the car for a while and take it to a non porsche specialist auto electrician to test the drain and check the alternator output.
Migration info. Legacy thread was 50877
Used Porsche
Watkins Glen
PostPosted: Sun Mar 26, 2006 12:27 am    Post subject: Reply with quote
Do a google search for bosche and look at their battery advice as well - low usage and short trips and weekends only and no top up charging and stereo and aircon and lights and god know what else electrical wrecks a battery - and if its 3 years old then its time for a new one!
And a bit of a run round wont fully charge a very flat battery - 18 hours overnight on a trickle charger will - you can get one on this site.
By the way the same applies to 996's as well. And Vectras!
Get more info here
http://www.batterystuff.com/tutorial_battery.html
Migration info. Legacy thread was 50878
F1_Dragon
PostPosted: Sun Mar 26, 2006 11:47 am    Post subject: Reply with quote
Stevo, thanks for advice, i forgot to say I had already done a search - very useful info...I did notice you popped up on every battery thread with words of wisedom...batteries seem to be a sort of personal crusade! Wink
Would buy a trickle charger but do not have mains supply in my garage... Sad
But still wasn't clear for 996s if people just get new batteries from OPCs or is it possible to get porsche 'badged' batteries elsewhere cheaper? I want to make sure I stick with Porsche OEM parts...or am i taking things too far?
Thanks!
Migration info. Legacy thread was 50891
Haran
996C4S
Used Porsche
Watkins Glen
PostPosted: Sun Mar 26, 2006 1:39 pm    Post subject: Reply with quote
I have a New Bosche Silver and a previously bought 120 Porsche badged one from Guidford Porsche - in my opinion there is no material difference where it matters - how long it stays charged. I now keep one on trickle charge with the same make of charger as sold here - then swap them over when one starts to fade.
My car has a battery switch with a removable key under the bonnet and the previous service history shows a battery replacement after 20k miles. I have now done 46k miles.
One problem that made mine worse was the incorrect wiring of the radio when I changed to Alpine - it left the CD stack and main radio permanently on - this was found by Ray Northways (independant) when I had the last service.
In my opinion - get a Bosche. - you'll have the money left to get another on 3 years if you need to!
Migration info. Legacy thread was 50899
F1_Dragon
PostPosted: Sun Mar 26, 2006 6:06 pm    Post subject: Reply with quote
Thanks again Stevo.
Battery completely dead today, so will begin surfing for replacment. Sad
chrs.
Migration info. Legacy thread was 50920
Haran
996C4S
Pixelation
1995 Porsche 993 Carrera 4
PostPosted: Sun Mar 26, 2006 9:01 pm    Post subject: Reply with quote
where's the cheapest place to get a Bosch Silver battery from??
Migration info. Legacy thread was 50927
F1_Dragon
PostPosted: Sun Mar 26, 2006 9:24 pm    Post subject: Reply with quote
Costco seem to be the cheapest...but you have to be, or know somebody who is a member.
Migration info. Legacy thread was 50930
Haran
996C4S
F1_Dragon
PostPosted: Mon Mar 27, 2006 10:24 am    Post subject: Reply with quote
Hmmm...OPC want 143 for a battery, 201 inc fitting and they want to do a drain test bringing total up to 259.
seems a bit steep to replace battery.... Sad
Is anybody able to give me size/details of their 80AmpHr 996 battery so i can get quotes elsewhere? OPC wouldn't give me details and mine is currently stuck in car at home with lids locked.
TIA
Migration info. Legacy thread was 50967
Haran
996C4S
steve cutler
PostPosted: Tue Mar 28, 2006 7:52 am    Post subject: Reply with quote
I just went inyo Halfrauds and got one off the shelf for mine....fits and works a treat, can't remember exactly how much, but a lot less than 143, and the fitting was free.... Smile
Remember to have the ignition on when you change it though.... Smile
Migration info. Legacy thread was 51104
F1_Dragon
PostPosted: Tue Mar 28, 2006 8:43 am    Post subject: Reply with quote
Cheers Steve.
The nice chaps at JAZ in Wembley are going to do me a Bosch for 70...I will still be able to sit down after that... Wink
Migration info. Legacy thread was 51110
Haran
996C4S
Tiptronic
Shanghai
PostPosted: Tue Mar 28, 2006 8:56 am    Post subject: Reply with quote
Thats a horrific price for a battery, whos the parts manager Vincent Price?
Stick with Jaz.
Regards,
Daz
Migration info. Legacy thread was 51117
Jay T
PostPosted: Tue Mar 28, 2006 9:28 am    Post subject: Reply with quote
Previous poster wrote:
LOL Very Happy
Migration info. Legacy thread was 51133
supersport
1987 Porsche 911 3.2 Carrera Supersport
PostPosted: Tue Mar 28, 2006 3:07 pm    Post subject: Reply with quote
Get you local friendly sparky to come along and wire up a nice feed to your garage, cost me about 400. Is a little expensive just to run a trickle charger, but I got lighting and some sockets too.
Amazing the wife agreed to it, but is very handy, especially at night and over the winter when the car wasn't used.
Mark.
Migration info. Legacy thread was 51208
Mark
1987 911 Carerra 3.2 Supersport
LOJO
PostPosted: Tue Mar 28, 2006 7:49 pm    Post subject: Reply with quote
Mark, you are doing it wrong -
1. Get the wife to push start you a couple of times.
2. Suggest that you need to spend 400 on a power source.
3. She will be happy to sponsor you!!
LJ
Migration info. Legacy thread was 51259
996 C2
F1_Dragon
PostPosted: Wed Mar 29, 2006 12:01 pm    Post subject: Reply with quote
Got new Battery from JAZ this morning after being jump started by RAC at 7am. Not sure the neighbours appreciated the alarm wake up call when i tried to disarm alarm Embarassed
Really nice bunch of guys, nice cup of tea while i waited, and they had a lovely speed yellow 964 RSR in to look at....yummy.... Laughing
Migration info. Legacy thread was 51335
Haran
996C4S
wagonface
1991 Porsche 964 Turbo
PostPosted: Tue Apr 04, 2006 9:33 am    Post subject: Reply with quote
Having had months of battery problems, I have some adviuce to offer, but also some questions I still need answering.
Battery going flat - solutions:- trickle charger plugged into mains (I suggest Halfords). If you get one that plugs into your ciggy lighter, you need to get the wiring changed on the car so the cig lighter is live after you turn things off (apparently normally all circuits are shut down after switch off)- solar panel charger. I had to go for this as I park on the street. Not sure how effective it is, but its my only option. I got mine from the really nice chaps at Select Solar:
Battery going flat - why?- I use my car sparingly (2x20min journeys during the week, 2x30mins at weekend)- Even with a brand new Porsche battery (130 thank you very much) I had major problems with it draining in winter (summer isnt as bad due to atmospheric pressure)- Even after a 1hr drive on the weekend, 5 days later its flat and setting the alarm off- 4 OPM's and 3 independents told me this isnt great, but is certainly not out of the ordinary. When I asked them what I do when I go on holiday for 2 weeks, they had no answer. Great, very helpful.- OPM diagnostic expert had my car for 5 days and cant find anything wrong with it (drain is around 0.078A, charge rate is okay apparently)
Useful things to know:- a well charged battery should read around 12.2v on the guage (or your voltmeter) when engine not running. Mine commonly reads lower than 12v after being left ofr a few days- with engine running, battery charging is indicated by guage reading in excess of 13.8v- standard operating voltage with engine running (when batt charged) is around 13.8v- If you have a tracker, you should always charge the car battery fully connected in the car, as you need to charge the tracker batt's at the same time.- when getting a batt charged by a garage, check if they have a 3-phase charger (it really sorts things out and is the best way of charging a batt, but does take up to 48 hours)- A flat battery needs at least a 2hr drive in the car to charge it, with some solid drives in the following days. Don't jump it, do a 30min drive and think you'll be fine.- read your manual and connect jump leads to engine, as specified
Tracker:- I have a Tracker installed and it is the only thing I havent had fully tested yet- tracker insist there is nothing wrong with it, but if its batt's have discharged a few times, and they are 3.5yrs old, it could be that they dont last very long and once flat they create a large drain on the car batt, or start shorting it- Tracker coming to investigate next week (80 call out, again delighted)
Questions:- anyone else suffer this poor battery life? (assuming low levels of car usage)- anyone figured out how to put a battery disconnect switch into a 996? (difficult as it messes with the alarm)- anyone figured how to disconnect battery but lock all car doors (I dont mind the alarm being off, but cant leave it unlocked on the street!)
Migration info. Legacy thread was 52229
964 3.3 Turbo
ex: 996 C2 Cab
Fuchs
Shanghai
1994 Porsche 993 Carrera 2
PostPosted: Tue Apr 04, 2006 9:47 am    Post subject: Reply with quote
with a 993 - to lock the car and not set the battery you need to do the following.
Close drivers door, walk around car and from the pax door centrally lock the car using the rocker switch on dash, close pax door and car is locked and alarm not set.
Migration info. Legacy thread was 52235
1994 Carrera 2
Ex 1984 Carrera 3.2
Used Porsche
Watkins Glen
PostPosted: Wed Apr 05, 2006 7:25 pm    Post subject: Reply with quote
Hope this helps.
I also have 2 batteries - one in the car and one on charge.
A good auto electrician will track down a discharge problem.
My replacement radio/cd system was wired incorrectly which drained the battery in about 4 days.
battery solar charger....
Battery cut off switch...
Hope this helps.
Migration info. Legacy thread was 52500
Porsche
2003 Porsche 996 GT3 Mk2
PostPosted: Wed Apr 05, 2006 10:44 pm    Post subject: Reply with quote
damn it's like battery failure season !! Confused
Migration info. Legacy thread was 52525
Porsche on Youtube!
964 Project Car
996 MK2 GT3 CS Manthey
993 Targa
