alarm help!
mikeh
11 Mar 2006
5
hi, i've got a alarm problem on 1998 uk 996 C2 started a few weeks ago and i've tried but can't fix it.
The alarm siren seems to go off for no apparent reason for a minute a a time then off but then straight off again. It's only the siren and not the flashers and the car can be started so the immobiliser is not getting activated. The only way to stop the alarm because the fob desn't turn the siren off is to take the negative battery lead off, however, normally you need the ignition on else the siren would go off but in this case without the key in the battery disconnection kills the siren. It's fine to drive and the siren doesn't go off when it's driven, and ocassionly i can set the alarm and it wouldn't go off for an hour or so. i've checked the normal doors, bonnet etc contacts and all seem ok and no obvious bleep as if something has been left open (have checked it open door and bleep does indicate open door). Checked radio on someone advice and seems ok, tried unplugging siren next to battery but backup siren which i think is the high tone horn still sounds. Someone also suggested locking and unlocking the car a few times then starting it up but seems to have no effect and not sure if there's a certain way of doing the locking and unlocking in a certain time frame. Tried looking through the workshop CD a have but 90 pages of alarm info and all dutch to me! can anyone help?
mike
Migration info. Legacy thread was 49824
heard that it may be an indicator that your battery mite not be powering the alarm/rest of car properly. So the alarm sounds to say "listen to me, i'm going to annoy you and all your neighbours for ages and make you look like a right plonker, you need to change the battery because its not powering me properly" :D
Apparently this is common on cars which sit around alot.
Migration info. Legacy thread was 50119
thanks but it was the siren and needed replacement at £200 so alot lighter in the pocket.
cheers
Migration info. Legacy thread was 50180
oh ok, i'm having trouble with my alarm now, must have caught your bug!! see my other post.
Migration info. Legacy thread was 50793
124,609
1,442,043
49,039
thatandywhite
