Darren Weston
- Joined
- 15 Jan 2006
- Messages
- 5
I have just got my first Porsche which is a 2003 996 C4 cab, has anyone any suggestions how I can stop any of the below rattles.
1. The hard top squeeks every time you run over a match stick.
2. Both door panels make a vibrating noise when on idol.
3. I have a noise which I can only describe as a hamster in a wheel at the back of my glove box. I have traced this to an actuator that keeps moving (located at the very top left of the fan unit) when the auto setting on the air con is switched on. When this is turned to manual, the actuator stops fluctuating and the noise stops, it is not a fan noise.
4. Anyone got any suggested tyre pressures, the car has 18" wheels?
Darren
Migration info. Legacy thread was 42897
Darren
