991 : 2011- 19
997 : 2004- 73
993 : 1993-1998 7
Boxster : 1997- 32
Cayman : 2005- 20
Chris Fegan
PostPosted: Mon Sep 12, 2005 10:44 am    Post subject: Reply with quote
Good morning all you Porsche nuts!!
I'm a relatively new owner of a gorgeous 964, child hood dream come true. Just put her through the MOT and flew through everything except the lights haven't been converted from LHD to UK roads.
Help here please, do you just need to replaced the glass lense, is there a conversion kit or doyou need to replace the whole unit?? Any help would be appreciated and source of where to get the solution would be good.
Figsy - One happy driver!!!
Migration info. Legacy thread was 33675
Hendo
PostPosted: Mon Sep 12, 2005 11:11 am    Post subject: Reply with quote
I had no joy a few years ago and was advised to change the whole units. That was by RUF when they were in weybridge.
Migration info. Legacy thread was 33677
911mot
PostPosted: Mon Sep 12, 2005 6:41 pm    Post subject: Reply with quote
Its tricky to find a beam coverter to enable LHD to use UK roads. The kits you can buy in places like Halfords are stickers that blank of the section of the lens that gives the beam it's kick up. On UK cars the kick up is towards the kerb and if used abroad that means into the eyes of cars coming the oppsite way
The reason RHD stickers wont work on LHD headlamps is because the ellipsoid shape stamped into the h/lamp glass is in a different place and of a different shape.
It can be done though. Buy a RHD kit, invert it (sticky side up) and use it as a template to make your own out of something like sticky back vinyl.
The correct and more permant fix is of course new lenses.
PS you only need to eliminate the kick up to pass the MOT. (I'm a tester myself ) So don't let them force you into new headlamps if you don't want/cant afford them.
Good luck
Migration info. Legacy thread was 33697
