I did wonder if you were able to source your car in Eire or if you were faced with importing. I recall the duty being huge. We have friends who are based in Dublin and Enniskillon, so I don't know if they had a way around that particular problem.
Met my better half in Dublin but thats another story.
Don't get the wrong idea about my experiences. I started off looking for a cheap convertible as part of my mid-life crisis, was pointed at the 968 and then road tested a 911, a car I'd never thought of buying, simply on grounds of cost. Smitten by the experience, I moved on to look at car after car but mainly 3.2 variants including the SE and SSE that was the subject of your other thread. I also spent a lot of time reading about the marque but not enough before I was bowled over by the turbo and spent far more than I intended but, at least so far, without regret. Mine isn't an every day car so the criteria are different.
If it's going to be day to day transport and based on the advice I received, I think a normally aspirated 3.2 coupe SE or SSE would be a more sensible choice with the Targa being a good open top compromise if the leaks and squeaks have been sorted. Personally I'd consider a targa for normal use and a coupe if I was headed for the track. Air conditioning should be near to top of your check list.
The G50 gearbox should be on the list as well because even if there is nothing wrong with its predecessor, lots of people say go for the G50 so it should be easier to sell on.
You might also find that the 964 is within your budget as they date from 1990. Lots of people dismiss the car and its looks seem to provoke some negative comment, but its a Porsche with accessories that make every day city life far easier (p/s for a start!) and you could find one that all of the known problems have been addressed at someone elses expense.
As to the better half, well my Toy provokes virtually no negative comment but then it wan't bought to transport the three kids! If I'd known more about Porsches, then I'd have bought one years ago, so perhaps now is the right time for you, before the wedding and the children, by which time she might insist on a Cayenne
or an RS2 or 4?
Migration info. Legacy thread was 20689
