Erratic revving
Amolak
4 Jul 2004
16
Hi, Sometimes when I drive my car it starts to rev up and down itself between 500-2000rpm. If I apply the throttle it sometimes cuts out. What could cause this?, it is intermittent. thanks Amolak
Migration info. Legacy thread was 19103
what model?
Migration info. Legacy thread was 19109
opps!
1986 Carrera 3.2 manual UK model.
cheers
Amolak
Migration info. Legacy thread was 19110
could be a vacuum pipe loose or missing?
Migration info. Legacy thread was 19111
Sounds like a fuel mixture problem, probably running too rich if hunts at tickover and sometimes dies.
Could be caused by a loose vacuum pipe as Poon says, check all the tubes and connections round the back of the engine (not the easiest of jobs).
To get the mixture set properly you need to take it to a garage with a CO meter. Just make sure all the pipes are fine before you get the engine tuned.
Matt.
Migration info. Legacy thread was 19128
Hi
friend of mine had same sort of problem on his 993 came down to the airmast sensor thought his car was at several thousand feet on and of therefore ajusts the air intake accordingly
hope this helps
Migration info. Legacy thread was 19707
Previous poster said:
Idle stabiliser valve? been playing with mine (993) to get it to run right with a LWFW - produces the same problem if adjusted too far
marc
Migration info. Legacy thread was 20326
Correct - idle stabiliser - remove - clean carefully the internals and replace - done!
Migration info. Legacy thread was 20341
124,592
1,441,901
49,025
StephCafe
