Peter Chase
- Joined
- 19 Mar 2003
- Messages
- 13
My 1979 SC coupe sunroof is leaking a bit. I noticed that the seal on the front side of the body is worn out, which is probably the problem, as the leak is at the front.
I plan to replace this seal. I see that seals are available to purchase. There are long and short versions. I think I need the short version. Does that sound right for my car?
Has anyone any hints or tips to make the job of removing the old seal and replacing with new seal easier, or to achieve a better seal?
I see that there is a Pelican Parts article on sunroofs. It mostly deals with the mechanism, though, and my mechanism works fine (if rather noisily).
Migration info. Legacy thread was 10002
