993 steering wheel vibration
andyphilpott
31 Oct 2002
241
Chaps
Why would the steering wheel vibrate, only on certain surfaces, under braking, generally around the 60-45mph mark. It doesn't happen all the time, but on some ocassions it is alsmost violent shuddering. I've had a four wheel alignement done and both front wheels balanced, so my only thought is that it must be a warped disk, which while minor can be affected by road surfaces. Any thoughts as the dealer does not think there is a problem, so I suspect it's one of those thing's I'll have to get done myself. Any ideas? Ta Car is 1996 Targa
Migration info. Legacy thread was 2125
Put the dealer in the car with you & make it happen!
Not sure about the 993's, but apparently the 964's can be sensitive to the wheels not going back on perfectly square which gives a feeling as if a disc is warped.
A quick check is to ensure that the mating surfaces of each wheel & hub are perfectly clean & smooth,no thick paint,corrosion or dirt buildup.
If it's under warranty, get back there and make the dealer sit up & listen, the last thing you want to happen is to experience this when you're having to deal with an unexpected problem out on the roads - a recipeforan accidentifever I saw one.
Hope you sort it out.
cheers
Andy
Migration info. Legacy thread was 2126
Any chance it is a problem with the ABS?
Migration info. Legacy thread was 2132
had a similar problem with my BMW 528 after a wheel refurb when the missus curb it. Unfortunatly did not get to the bottom of but it was improve by a very precise wheel balance by some BMW wheel technician.
Migration info. Legacy thread was 2162
124,555
1,441,474
48,969
Stulees65
