baiselmareo6
- Joined
- 27 Mar 2020
- Messages
- 1
How light can you make a Porsche 550 ?
Like what is the absolute lowest weight you can get it down to ?
This is assuming you do everything possible-
If you strip absolutely everything out, use composite materials, fibreglass, molybdenum, carbon fibre and all of that fancy sounding stuff. Maybe use a modern lightweight engine if it helps, or tube-frame chassis, etc. Basically do literally everything you can to save weight.
Could you get it down to 1000 pounds ? 800 ? Less ?
