SpennyUK71
- Joined
- 29 Jan 2018
- Messages
- 28
Hi all
Reference 2002 C4 tiptronic with PSM.
I am looking at replacing all flexible brake lines with stainless steel alternatives, whilst at the same time, I am looking to remove the callipers for a full clean, inspection, refurb where required and new paint.
The question I have relates to the brake bleed. In the 101 projects book by Wayne Dempsey, it states the following...
For cars with traction control or Porsche Stability Management (PSM), you need to use the Porsche System Tester 2 (PST2) in order to activate the valves in the hydraulic unit during the bleeding process... you will need to go to a shop that has a PST2 so that the brake system can be bled properly.
I am not looking to do a full flush as my fluid has been changed in the last year, so is the use of a PST2 really necessary for a top up to replace what will be lost only from the flexible brake lines and callipers?
I appreciate any help you can provide :thumb:
