Hi All I am new to this so bear with me please. I have a 2005 987 Boxster S which I purchased less than a month ago. Went to put the hood down and heard a couple of bangs everything worked apart from the top folding. Tried a couple of times with no change. On investigation the plastic ball joints for the top lever were found broken. Wife had the car out a few days later in the rain, brought it home and lots of electrical things were happening lights switching on and alarm going off etc. After looking on a few forums I discovered the passenger floor carpet was soaked . Next day the battery was flat so I disconnected it and put on charge. Removed the passenger seat and used a wet vac to get most of water out and currently using a dehumidifier to dry it out. The ECU below the seat had been water damaged so I removed and cleaned with electrical cleaner and it looks fine but hard to tell if it is not fried. All put back together and everything is working as it should apart from the folding roof. I don't have any alarms on the dash but when I disengage the roof lock and operate the switch nothing happens. The windows don't drop and I can't hear anything trying to operate. I suppose it could be the relay but would both go at the same time ? Also I can't get the roof into the service position to try to fault find the leak or possible blocked drain. Any ideas please?
