My car is specced with PCM1 (16 bit) with BOSE - this has the cassette in the dash, 6CD changer and BOSE amplifier in the boot and the single DIN navigation drive in the centre console. I believe this is a non-MOST system. It has door speakers and a subwoofer behind the rear seats. The 6CD changer is non-functional and the FM radio is limited (I'd like DAB for 6 Music), and I need some sort of Bluetooth/USB connectivity for my Iphone. Otherwise it all works perfectly, including the sim-card/phone, the navigation and all of the other functionality. It even sounds pretty good!
I'd like to add DAB and Bluetooth to this system and I wonder if there is any advice here as to my options and connectivity. My intention for the car is to keep it pretty much OEM+ but with a fast-road flavour; as such I would consider a centre console delete at some point to free up legroom so any replacement would need to be single DIN to work in this configuration. I would also like something that looks period and of suitable quality.
The options I can see are as follows:
1. get a bluetooth adapter for the PCM1 for about £150 which connects into the old cd changer cables and will allow me to use my Iphone for DAB and streaming music. This is an easy option which will allow the car to stay OEM looking, but no DAB functionality.
2. get a new single DIN head unit with DAB and Bluetooth (these seem quite thin on the ground surprisingly). I'm thinking something like the Continental TRD7412 which seems great except this doesn't have pre-outs to interface with the BOSE. There is the Blaupunkt Bremen which seems perfect but is very expensive and a bit too retro looking for the 996. This leaves some more modern units like the Alpine UTE-93DAB which are available for around £180 and seem to offer the functionality I need if not the retro-ish looks.
In terms of mounting this I was considering putting it into the slot currently occupied by the Navigation drive for the time being, assuming the the centre console delete will happen at a later date. Is this possible? I assume I will need to pull the PCM1 to connect the wiring harness into the new head unit, will it be long enough to reach the lower position in the centre console? I would then just pop the PCM1 back into place where it can fill the big hole in the dash until I'm ready to do the console delete.
3. Get a double DIN unit to replace the PCM and change the navigation drive for a cubby hole. I'm not that keen on this look and I don't really need all the extra functionality.
Finally, in connecting a new head unit into the BOSE system am I just looking for a single set of 2V pre-outs via RCA to make his work? Is there anything else I need to worry about interfacing the three connector blocks on the PCM into the new head unit? Can I just buy an off the shelf harness adapter?
Sorry about all the questions, I'm going to lose it if I have to listen to any more Radio 2!
