NineExcellence
- Joined
- 21 Sep 2009
- Messages
- 1,588
Nine Excellence (9e) are offering the following to existing and new customers in conjunction with Kline. All orders to be placed by email to [email protected] - we will contact you back.
Kline Exhaust systems
- 25% off all Retail Price for all Porsche models. Call for price or check online
http://www.nineexcellence.com/upgrades/exhausts.html
Select your make and model.
- includes 25% discount on manifolds and carbon tips as well.
- delivery free in UK (call for overseas)
Terms and conditions.
- All of the offers below are conditional that the booking is made between 28th November and Monday 2nd December 17:00.
- Booking made only via email - if you have questions then we will call you back.
- Offer code 9EBF2019 must be quoted
- Any additional work required is charged at normal parts and labour rate
About Kline Exhausts
Kline Innovation believe in the absolute best materials for every application, chosen scientifically by the materials natural properties. Titanium/Inconel/Carbon fiber exhaust boutique, and of course they offer 304 stainless steel as an alternative on the complete range. Every material has its own unique properties, and perfect application based on weight, strength, heat resistance, and chemical stability. Kline strive to craft some of the worlds best lightweight exhausts utilising every innovation possible!
Catalysts
Kline only uses HJS 200cpsi (100cpsi is available on request) which have been developed by HJS on the basis of their motorsport catalysts. They provide the best performance , whether 100cpsi or 200cpsi and on average offer up to 12kW more power.
Inconel
Inconel 625, as used in the aerospace industry where extremely durable and heat withstanding components are required, for example for the exhaust turbine blades in high performance jet engines. Inconel is also used for the manufacture of formula one exhausts, and has also been used by some manufacturers on hypercar projects such as Mcalren P1, Aston Martin 177, where lightness is a factor, and exhaust temperatures regularly exceed 1000c.
The basic properties of Inconel are characterised by extremely high tensile strength, and extreme thermo chemical stability. because of the high tensile strength of inconel (roughly the same strength to weight ratio as titanium), very thin sidewall material can be used, while still maintaining structural integrity, resulting in very light weight components that will not fatigue over time. The main drawbacks to using Inconel,is that its extremely difficult to machine and weld, and requires high skill and time consuming processes. its also extremely expensive as a raw material
Carbon Fibre
Carbon fibre reinforced polymer has an extremely high tensile strength to weight ratio, surpassing that of all metals. Extremely light weight and high tensile strength components can be molded to almost any shape. We exclusively use aerospace, and formula 1 grade pre-preg carbon fiber, cured in an autoclave at high pressure and temperature, to achieve the lightest and strongest carbon fiber for the most extreme conditions.
Catalysts
Inconel
Carbon Fibre
