I'm not going to get around to fitting this to my car.
genuine kit removed from a breaker.
Cruise tempomat (actuator + ecu)
Throttle pedal with extra cable
Clutch switch
Just needs a cruise stalk and a wiring loom making up and fitting. I think you don't need to use a computer to code this in on these cars, as the cruise ECU is in the tempomat, but you might not get the light in the dash I don't know.
Fitting instruction and wiring diagram PDF for the loom needed are here halfway down the page (Richard Hamilton)
https://www.renntech.org/topic/3532-adding-cruise-control-to-a-my98/?page=2
Clutch switch
