Ok so this is my first Porsche, 2005 997.1, and I love it.
Few jobs needed doing and only yesterday I ticked another off the list.
I bought it knowing the CD changer didn't work or even register, bi5 after reading lots about it I stripped it out yesterday took it to pieces on my dining table after testing and finding I had bother 12 volts and optic signal.
After stripping down quite some way I found the cartridge eject mechanism and released the cartridge where I found 3-4 disks inside.
On removing I found one cd that has a split in it at least 1cm from the edge.
Clearly this was the cause of the jam.
Put it all back together and refitted in the Frunk, to find it worked?.
BUT, for the life of me I cannot find how to change disk using the PCM, I thought you pressed the CD button then the corresponding disk number?
This doesn't work, all disks are highlighted and it automatically goes to next disk at end of play of first disk.
how do you advance a disk or select a given disk?
Lee.
Lee.
