997 : 2004- 64
Cayman : 2005- 22
Macan : 2014- 8
uk996
PostPosted: Tue Sep 24, 2019 10:45 pm    Post subject: battery drain Reply with quote
I found that my car would drain its battery in about 3 weeks. Just found that the glovebox light stays on and never goes out. Haven't found the switch for it yet.
2002 996tt Aero in seal grey 6MT
Macca38
PostPosted: Wed Sep 25, 2019 10:48 am    Post subject: Re: battery drain Reply with quote
Does the car have a tracker? They are terrible for draining batteries.....
Lukec4s
PostPosted: Wed Sep 25, 2019 10:49 am    Post subject: Reply with quote
I had battery issues a while back and at one time thought it was the glove box light. I think it eventually turns off but takes a while. If you want to eliminate that as the cause then pull the bulb and see. I even pulled the trunk light too.
My issue ended up being alternator related
Ferrari 360
996 c4s
Clio 182 track car - it’s fun
uk996
PostPosted: Wed Sep 25, 2019 1:06 pm    Post subject: Reply with quote
I videoed the inside of the glovebox with my phone, it was on for 45 mins.
It doesn’t have a tracker, not one I’m aware of ...
PostPosted: Wed Sep 25, 2019 6:32 pm    Post subject: Reply with quote
You need to drop the glove box to get at the switch .. it's on the right side of the box .
From memory you can just about get a finger to it but basically you need to remove the box and test / replace it .
Amp meter on a battery neg lead and read off after 1 hour to see if you have a discharge .
Mac996t
2004 Porsche 996 Turbo
PostPosted: Wed Sep 25, 2019 9:32 pm    Post subject: Reply with quote
Did you have either the bonnet or engine cover open while checking the glove box lamp. Our car are strange in that the front boot lamp, engine bay light and glove box light all work together so they all come on if any of the three are open,
This means if you leave one of them open all three will stay on, but the cleaver car turns them off after about 45 mins so you don’t flatten the battery!
Rik b
2002 Porsche 996 Carrera 2
PostPosted: Thu Sep 26, 2019 1:23 am    Post subject: Reply with quote
Hi
I had this on a C2 cab and it was a dodgy ignition switch. It took ages to ID but £45 to fix.
Good luck
uk996
PostPosted: Thu Sep 26, 2019 6:26 pm    Post subject: Reply with quote
darn it, yes the frunk lid wasn't closed properly, I do that deliberately so I can get to the battery easily if needed.
Also it looks like I need to check for over an hour to make sure.
Back to square 1.
uk996
PostPosted: Sun Sep 29, 2019 8:03 am    Post subject: Reply with quote
thanks for that deMort. I've got a clamp meter that'll do the job. I don't suppose you know the pin outs / wiring the diagram for the Bose system on a 2002 911 ? I've found a control box and amplifier in the frunk and would like to replace it with an after market amp I took out of a previous car I had.
