997 : 2004- 63
Cayman : 2005- 22
Macan : 2014- 7
Jay Are
PostPosted: Sat Sep 07, 2019 4:52 pm    Post subject: Stupid Question - 996 vs 997 gear throw Reply with quote
Is the throw on the 996 turbo gear shift longer than a 987 or 997?
How do i get the specs for such a comparison??
JR
987 turbo S
PostPosted: Sat Sep 07, 2019 4:55 pm    Post subject: Reply with quote
Might be better asking in the 997 sub section as more 997 turbo owners have owned a 996 turbo rather than the other way round.
NickHappy
PostPosted: Sat Sep 07, 2019 8:35 pm    Post subject: Re: Stupid Question - 996 vs 997 gear throw Reply with quote
JR
I would say so - yes. My 996 turbo was fitted with SS, my 997 turbo is standard but feels the same.
Hope that helps
997 turbo Manual.
996 turbo Manual. ex.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sat Sep 07, 2019 8:39 pm    Post subject: Reply with quote
I believe the G97 gearbox throw is 15% shorter than the G96. Not sure if that applies to turbos as well as Carreras.
Dammit
PostPosted: Sat Sep 07, 2019 8:49 pm    Post subject: Reply with quote
I believe it is, I purchased the 997 GT3 shifter for my car, which with the stock lever felt good - very precise and slightly shorter in throw than the stock 996 unit which it replaced.
Then I fitted a Function First shifter which is much longer than the OEM shifter, and it made the shift too ponderous - I changed that for the 997 SSK shift unit and it bought the shift throw back to a nice length.
PostPosted: Sat Sep 07, 2019 8:53 pm    Post subject: Reply with quote
This has given me an idea. I think I could make my solid bearing ssk adjustable on the throw so users can set them to their own preference.
Dammit
PostPosted: Sat Sep 07, 2019 8:56 pm    Post subject: Reply with quote
That would be very handy.
maldren
PostPosted: Sun Sep 08, 2019 8:15 am    Post subject: Reply with quote
I changed from 996 to 997 and Alex added his custom bearing set up. The shift is about 1" less front to back, closer to the original shift travel than the short shift kits which I personally found too short and notchy and an excellent upgrade.
Mike
Marky911
PostPosted: Sun Sep 08, 2019 10:14 am    Post subject: Reply with quote
Oops, ignore this. Posted in wrong thread.
We need a delete option on here. Wink
Jay Are
PostPosted: Mon Sep 30, 2019 9:31 pm    Post subject: Reply with quote
Cheers guys,
I thought that might be the case. The G96.50 is also, basily a tractor unit by all accounts. I think they must have softened the gearbox/ change with the 997 methinks which enabled the shorter throw...
Right, off to find the 996 gear change mechanism to measure!!!
987 turbo S
skinny_monkey
PostPosted: Tue Oct 01, 2019 9:52 pm    Post subject: Reply with quote
For the std carrera it's an upgrade going to a 997 gear lever in terms of taking out slop and also shortening up the throw just a little (not enough to make it notchy, just nice)
