997 : 2004- 64
Cayman : 2005- 22
Macan : 2014- 8
PostPosted: Wed Aug 28, 2019 7:09 pm    Post subject: Skill . Reply with quote
Very few times have i ever managed this !
Hats off to anyone that has .
 Filesize:  88.37 KB
 Viewed:  1511 Time(s)
PostPosted: Wed Aug 28, 2019 7:15 pm    Post subject: Reply with quote
Grin Thumb
ELA
PostPosted: Wed Aug 28, 2019 7:17 pm    Post subject: Reply with quote
Top-Tip Iain, the Snap-on easy outs are very good, many of the others are best left alone due to their chocolate tendancies Thumb
CLR996 1086kg bespoke design
kurlykris
PostPosted: Wed Aug 28, 2019 7:21 pm    Post subject: Reply with quote
In 35 years of engineering, I reckon I`ve managed that once Iain Grin
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
Bane of my life is snapping taps in jobs. Now that is a F***er!! frustrated
PostPosted: Wed Aug 28, 2019 8:20 pm    Post subject: Reply with quote
OMG .. a snapped tap is bad .. very bad .. i hate this sort of thing , always feels me with dread and i'm sure every other mech out there .
Snapped tap .. hardened steel ? how the hell do you drill that out in situ .
To me .. this is engineering work and they are the experts .. Alex .. worship
I even bought a set of left hand drills for the next time .. doubt they will work but i need options .
I have colleagues that seem to have no problems but for me .. i'm just not good enough and i don't care admitting it !
This is an art .. give me electrics any day lol .
Snap-on do make excellent tools . not cheap though .
But .. to achieve that once in a lifetime drill out as the picture shows .. that's got to be better than sex Floor
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Aug 28, 2019 8:28 pm    Post subject: Reply with quote
I have just bought a few left handed drill bits for my Stomski exhaust jig. I'll be trying it in anger when they arrive.
Gray79
PostPosted: Wed Aug 28, 2019 8:55 pm    Post subject: Reply with quote
I’ve given up with easy outs, I usually weld a nut on the end of the sheared stud/bolt, the advantage of that is, it also puts heat into the stud/bolt.
997.1 Carrera 2S
PostPosted: Wed Aug 28, 2019 9:01 pm    Post subject: Reply with quote
My record for doing this .. 7 !!!
It actually came out on the last attempt .. nothing left of the bolt after that .. heat does work !!
PostPosted: Wed Aug 28, 2019 9:18 pm    Post subject: Reply with quote
Breaking taps......and removing looks something like this. A local place I use charge me around £20 to erode the tap out. That's cheap but by the time I've taken the job up there and collected then next day or so I'm around £70 out of pocket.
Open Youtube Page
Sometimes it's just cheaper to make a new part. nooo
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Wed Aug 28, 2019 10:35 pm    Post subject: Reply with quote
I bought a set a few years ago, they drilled a hole the same as a right handed bit and that was all, nothing shifted.
Luddite
PostPosted: Thu Aug 29, 2019 7:50 am    Post subject: Reply with quote
Looking at the pics of the extracted studs that Iain posted, it seems there is not much corrosion evident and that the threads look very clean which is far from the rusted crud I worked with for much of the time spent in the garage..I have managed at least once to use an easy out, but would lack confidence if faced with that which folk here have shared relative to removing exhaust manifolds from Porsche engines on the water cooled cars... ouch!
This vid might help, I have posted it before
https://www.youtube.com/watch?v=dJfkCj3FWBs
Windy101
PostPosted: Thu Aug 29, 2019 9:02 am    Post subject: Reply with quote
I once snapped an easy out while trying to extract a broken exhaust stud from a bike cylinder head - took me about 3 days to drill the b***ard out.
