Hi everyone,
Have discovered a huge amount of water puddled under passenger seat (towards rear) after a series of seemingly random error faults started appearing, starting with Start-Stop and including Power Steering, Type Pressure, Transmission etc etc.
Have eventually towel and sponged all of water out after pulling back the trim. Probably a couple of pints worth! Leaving to air overnight.
I am struggling to find any information on drainage hole locations that might be blocked. The car is parked outside and often near trees, I have owned it from new for 3.5 years.
I did also read something about a grommet recall on the tray for some 981s. Mine is a 2016 vintage so might have been for earlier models.
I also read about door seals as a potential culprit.
Also what electrics are in this area? Is the ECU near? I see the wiring loom heading off forward somewhere but can't see where due to seat brackets.
Car drives normally, but parking sensors are not working and the type pressure error message is appearing. Car had 2 year service last year at Brooklands.
Any ideas / suggestions much appreciated! (I am just out of the 3 year warranty of course)
