0740 - Torque Converter Lockup Clutch
noblebenn
10 Jul 2018
17
Carrera 3.4 Tiptronic.
Cleared the code and will take it for another run soon but doesn't sound to good!
Anyone with experience of this and any suggestions on things to try before I drop the gearbox out?
Mmmm! I had this couple of years after I bought my car, but there was no code shown in my case. I presume the activation is by a hydraulic actuator and in your case registering a fault. My problem, even though the symptoms of the TCC slippage is the same, must have been different.
Tried all the usual things like fluid / filter change, but to no avail. You might want to try that.
Had to get the box out and split it to repair. No problem since some 9 or 10 years later!!
If the car has not had a tip oil and filter change in years then do that first .. it's the cheapest first thing to do .
A low fluid lvl can trigger this fault .. so you look for leaks as well .
I've got a brand new unused and in the box TCC solenoid for an early 3.4 ZF tip box if you want to buy it ?
124,598
1,441,971
49,033
drthein
