Electronic steering column adjustment fault Cayenne S 4.8
baldlemur
11 Jul 2014
74
Hello all.
The electronic steering column adjustment on my '08 model Cayenne S only works in the horizontal in/out direction. The vertical adjustment doesn't work. Could one of the motors have failed? Does anyone know if these can be repaired? My local OPC says a full steering column replacement is required at just under £2500, which I won't be doing as the steering wheel position is fine for me; however, a repair might be worth considering, especially if I was to sell the car at some point.
Any thoughts / advice would be much appreciated.
John
MarkGolf said:
Do you hear anything when you press the up/down buttons?
I had this in my old 500SL and after pressing the button with some weight on the wheel, it started working, seems it got jammed. May be a similar thing..
Thanks. I will definitely give this suggestion a try.
UPDATE
For the sake of thread completeness and in case anyone else suffers the same fault - my local indy was able to free the steering column adjustment motor, which had got stuck at one end of its travel. This took about 30 mins labour (OPC told me steering column needed replacing at £2500 plus). Result!
124,600
1,441,980
49,035
Retep
