Car wont start!
antonio
1 Sep 2009
364
Hi all, car wouldnt start today, scanned for codes with torque app and got P2271. o2 sensor signal stuck, rich bank 1 sensor 2, could this be the cause? TIA.
Not really i'm afraid , that fault code to me would refer to the post cat lambda sensor on bank one seeing a rich mixture.
In other words your Cat is not working very well on that bank .
Does the car spin over but not fire up ?
does it cough and splutter but not fire up ?
An important question .. do you have a vts fitted .. do you have any black fobs that came with the car ?
If this has gone faulty the car wont spin over .
again a clutch switch fault and the car wont spin over .. if you hold the key in the start position for 5 seconds you will get a message saying depress clutch .. this will say if its that ..
bit more info please :)
Hi Demort,
it does spin up but not fire, dont think i have VTS, after a while of trying to start the cel comes on though, Thanks
deMort said:
Interesting .. ok the engine light comes on and you only have the fault code you posted and nothing else listed ?
Thats correct Sir.
Ok .. we have a fault and the car doesn't see anything being wrong ..
That to me would indicate 1 of 2 possible faults ..
The fuel pump or lack of fuel due to it being empty shall we say will not generate a fault code .. the car has no way of monitoring this .
Only check is .. look in the tank or add 5 litres of fuel to make sure it's not a faulty fuel gauge and after that a pressure gauge on the fuel rail to confirm its got no pressure .
Second is the Crank Position Sensor .. only check is to scope the signal im afraid.
Your fault code , although not related could be in a roundabout way ... very low fuel pressure might .. and i mean .. just might generate this code .. fuel pump or lack of fuel is where i'm at with this though .
lets face it .. i don't have a lot to go on .. i cant see the car so i've done what i can !
Can i just confirm though .. you drove the car home , left it overnight and then this happened ? it wasn't jump started , put on charge .. left for a couple of years or anything like that ?
Cheers for the help it cant be easy without seeing the car, its been in the garage for a couple of days since i last drove it, all good till it wouldnt start this morning.
Thanks again, time to call the indy.
Sorry i can't give you a quick fix .. there are many things i would check if i had the car but from the info im leaning towards a fuel pump problem.
Hopefully its not too expensive when your Indy finds the fault and as always i would appreciate knowing what the fault turns out to be ... i learn every day on here which is a help in doing my job .
Thanks, i will check what i can then give them a call, ill let you know what they find
Following up on this does anyone know a good mobile mechanic in the East London/Essex area as my indy is not available at the moment, Thanks.
124,598
1,441,975
49,034
briant1000
