997 : 2004- 69
996 : 1997-2005 35
Boxster : 1997- 22
Milo72
PostPosted: Sun Mar 17, 2019 7:31 pm    Post subject: Plugging the resonator... Reply with quote
I could spend £90 for a kit but I read on hear someone plugging the hole in the air box with an aerosol lid.
I’ve been through the garage, shed and under the sink, none of them are the right side.
Anyone know what fits best ?
997.1 C2S Tip.
sja360
2007 Porsche 997 Carrera 4S
PostPosted: Sun Mar 17, 2019 7:37 pm    Post subject: Reply with quote
I've put a Gillette shaving foam plastic lid on mine, fits well.
PostPosted: Sun Mar 17, 2019 7:43 pm    Post subject: Reply with quote
I'm gonna run some aluminium ones off any day soon. Will be about a tenner a pop delivered,
Milo72
PostPosted: Sun Mar 17, 2019 8:11 pm    Post subject: Reply with quote
Thank you gentlemen.... Gillette Shaving Foam... I think I remember it being that, maybe it was your post I read. Does that fit into the air box end or up into the pipe?
Alex... I will have one off you if you do make them.
997.1 C2S Tip.
DucatiRob
PostPosted: Sun Mar 17, 2019 8:55 pm    Post subject: Reply with quote
Just trim it down with a stanley knife so it fits nicely over the airbox inlet then push the rubber hose over it and tighten the jubilee clip Thumb
Mercedes CLK DD
Ducati 996
kas750
Reims
2006 Porsche 911
PostPosted: Sun Mar 17, 2019 9:44 pm    Post subject: Reply with quote
Yes please Alex Thumb
NLW73
PostPosted: Mon Mar 18, 2019 6:43 am    Post subject: Reply with quote
One of those small Vaseline pot lids fit too
Spyder performance near Woking do a decent kit for 996 and 997 for £40:
https://nam06.safelinks.protection.outlook.com/?url=https%3A%2F%2Frover.ebay.com%2Frover%2F0%2F0%2F0%3Fmpre%3Dhttps%253A%252F%252Fwww.ebay.co.uk%252Fulk%252Fitm%252F332849907882&data=02%7C01%7Cnwelch%40microsoft.com%7C8bed618344d64d8a598908d6ab6d6df9%7C72f988bf86f141af91ab2d7cd011db47%7C1%7C0%7C636884883818402162&sdata=vbjX7qTLvV%2F7on6gp%2FDsAs58h%2BYvnRx3ZidU4XuhK2Y%3D&reserved=0
I am going to get rid of the resonator in the air box too to free up some air flow . Will get a mates dremel on it as they are plastic welded in. Unlike the 996 which is screwed in
Will get some pics up soon
997 C2s Schwarz
PostPosted: Mon Mar 18, 2019 9:03 am    Post subject: Reply with quote
Gents remember if you are leaving the resonator in situ then you need a cover but if your dremmeling out the resonator you will need a bung as the lip you put the cover on is part of the resonator and will not be there when you remove the resonator . Thumb
NLW73
PostPosted: Mon Mar 18, 2019 9:11 am    Post subject: Reply with quote
thanks phil
I am thinking cut it all out but then glue back in or try and keep the neck of the resonator in the air box so I can keep the bung in and the oem piping.
997 C2s Schwarz
