Had this on both front wheels of my 981 recently.
No apparently problem and then the dashboard tells you to check tyre pressures as one tyre is 0.1 or 0.2 bar below what it should be. Top up the tyre and all is well. Then a couple of weeks later it happened to the other front tyre.
Can't see anything stuck on the tyres, no sign of puncture etc.
The only thing that I can think of is that when I reverse out of the drive on cold rubber, the tyres tend to 'crab' sideways - I wondered if this is stressing the seal between the tyre bead and the wheel?
Any ideas?
Any ideas?
